08-29-2017, 02:10 PM | #1 |
Are duel tanks interchangeable?
A guy i know who wrecked an 87 Silverado with duel tanks. He's parting out the truck. The drivers side tank is badly damaged but the passenger side looked fine. I have a drivers side single tank and I'm looking for a replacement. My question is are these tanks interchangeable side to side?
Thanks |
08-29-2017, 02:15 PM | #2 |
Re: Are duel tanks interchangeable?
Yes,they are!
There is a left and right sending unit,but just the lines point opposite,and will still work. Mike. |
08-29-2017, 02:18 PM | #3 |
Great thanks!
08-29-2017, 09:58 PM | #4 |
is this a TBI truck? I'd like to buy the fuel pump wire harness (switch valve to pumps - both of them) if you can get it.
08-30-2017, 09:00 AM | #5 |
not sure but i can check back this weekend
08-30-2017, 11:52 AM | #6 |
ok sounds good and let me know. Thanks
09-10-2017, 05:22 PM | #7 |
I know some tanks are not and some are I got a 84 left side only tank put in a 77 right side. because a freind put the a hoist arm under the tank crushed it.
The 84 was not, I had the make up some rubber line for the sending uint pointed the wrong way. Too use it. I mostly depens on the sending unit flange welded to the tank top.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
