Old 09-10-2017, 05:50 PM   #1
Tiger Joe
Who makes good weatherstripping
Restoring my dads 79 dump. My dad ordered a complete kit from LMC. Needless to say we are regretting that.
Rubber bumpers for the hood are too thick. Took them out. Then we can't get the hood to shut, back is held up. What the heck it was perfect when we put it together before paint? Pulled off the new rubber cowl seal and bam! Hood lines up.
So is there a vendor that makes quality repo rubber products? This looks like fairly decent quality just everything is too thick
Tiger Joe is offline   Reply With Quote
Old 09-11-2017, 06:48 AM   #2
riz
Re: Who makes good weatherstripping
Steele Rubber Products is supposed to be awesome !
RIZ
81 C10 short box
82 K5 Blazer
riz is offline   Reply With Quote
Old 09-11-2017, 07:11 AM   #3
rickit
rickit's Avatar
cant speak for lmc weather strip but other stuff I'm getting from them is not working out nothing is lining up and not fitting
rickit is offline   Reply With Quote
Old 09-11-2017, 09:02 AM   #4
HunterRotten
HunterRotten's Avatar
It's to my understanding that Precision makes the best weatherstripping and it is what I have been working with. They're a manufacturer so you'll have to find a retailer (such as GMCPaul on his website. This is where I got mine from.) So far I haven't got to use everything in the kit but the vent windows are going together nicely. The rear window seal was very loose on my CR Laurence slider but I don't know if it was the rubber or the slider. Once it was in the truck it was very tight and looked great. Have not installed the chrome mylar yet.
HunterRotten is offline   Reply With Quote
Old 09-11-2017, 02:38 PM   #5
TKCR
TKCR's Avatar
Precision
Old 09-11-2017, 03:02 PM   #6
Pontiac1976
Pontiac1976's Avatar
When you replace the new rubber from old one you should readjust the doors, hood, and sometimes the windows with new rubbers because the old rubbers wore out sometimes flattened out.
The parts may have been re-adjusted make the tighter after so many years gone by.
All most all new rubbers made will be a little fatter and will flatten in years you may have to re-adjust them again, as the years go by.
Even if you got good old GM rubbers there going to have to be re-adjustments needed in cases.
I never used LMC rubbers yet have some small one. I have used Steele rubber & SoftSeals & one more I can’t think of it. Some good some could have been better work with tweaking & adjustment .
I here your pain been there
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 09-11-2017, 04:04 PM   #7
MikeB
MikeB's Avatar
I had good luck with Soffseal vent window seals on a 55 Chevy. https://www.soffseal.com/store/main.aspx
Was also impressed with the Steele weatherstripping a buddy of mine used on his 37 Chevy trunk lid.
Finally, I have no complaints about the beaded door window seals, glass channels, and vent window seals I got from Classic Parts. http://www.classicparts.com/
So, I must be easy to please.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 09-11-2017, 04:15 PM   #8
RotaryRocketeer
RotaryRocketeer's Avatar
I'm glad to happen upon this thread. I'm minutes away from confirming an order with LMC for a whole window channel kit. Is the consensus that their rubber products are subpar?! I'd always heard that they were the go-to for stuff for these trucks, but this is my first square.
RotaryRocketeer is offline   Reply With Quote
Old 09-11-2017, 04:40 PM   #9
MikeB
MikeB's Avatar
Well, they are the go-to vendor for exploded view drawings!
I can't speak to their weatherstripping, but I have been happy with the few parts I bought from them -- a heater control panel, windshield wiper switch, and some radiator brackets. However, their shipping charges are based on order total. So I paid $18.75 for an order that weighed less than 2 pounds.
I like the folks at Classic Parts. They bought Chevy Duty several years ago, a company that focused solely on old Chevy truck parts. And if you need it, they have tech support people who can intelligently answer your questions.
Mike
Old 09-12-2017, 07:29 AM   #10
Tiger Joe
I ordered a precision cowl seal to try out.
this isn't my first square body resto. Did an 87 roughly 15 years ago. i can say in that time the quality of stuff from LMC has gone from marginal at best to bad.
Old 09-12-2017, 08:37 AM   #11
Jstock85
My exp with LMC is hit and miss also. but i agree about the shipping charges because of that they are usually my last stop. Try rock auto. the prices are good and shipping is very reasonable.
Jstock85 is offline   Reply With Quote
Old 09-12-2017, 11:44 PM   #12
UKNOWME
UKNOWME's Avatar
I ordered a bunch of weatherstripping from LMC a couple years ago and all of it was Precision. Very please with the quality.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 09-13-2017, 07:24 AM   #13
riz
LMC gets a bad rap but they do carry name brands so if the parts are sub-par it's the manufacturers fault, not LMC for selling them.
RIZ
81 C10 short box
82 K5 Blazer
Old 09-13-2017, 12:48 PM   #14
PowerdbyChevy79
PowerdbyChevy79's Avatar
hit these guys up.. product is top notch...
https://www.prp.com/
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 09-13-2017, 01:02 PM   #15
RotaryRocketeer
I went ahead with my order at LMC. We'll see how it goes. Might try to post before and afters of the whole interior.
Old 09-13-2017, 02:59 PM   #16
wilkin250r
wilkin250r's Avatar
I agree and disagree. True, it's not "LMC" making bad products, but they make the decisions on what to buy and sell. If they decide to buy their reproduction rubber from Bob's Weatherstripping and Firewood, because they can make an extra 3% markup, then any bad reputation that results is totally justified.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 09-13-2017, 05:00 PM   #17
Jeff's bowtie's
Soffseal makes a good product as well as Steele rubber products I ordered my soff seal door seals from summit racing they price match plus ship free over $99.00 in most cases
Jeff's bowtie's is offline   Reply With Quote
Old 09-13-2017, 07:28 PM   #18
homemade87
I just wonder if GM is still making them . When I did my resto several years ago I got mine from the GM dealership for my 82.
Might be worth a phone call .
homemade87 is offline   Reply With Quote
Old 09-26-2018, 10:32 AM   #19
oldtimer1959
I always use Rubber the Right Way for rubber parts & weatherstrip. www.RubberTheRightWay.com. I have used for several vehicles and their parts are awesome. Everything is guaranteed to fit & the price is right.
oldtimer1959 is offline   Reply With Quote
Old 09-30-2018, 09:54 PM   #20
tucsonjwt
My experience with LMC rubber products is that they are very thin compared to OEM and the seem to not fit well. The hood hinge seals and cowl seal I got from them were not very good. The best windshield shop in town uses only Precision products. I need to replace my window run channels and beltline weatherstrip again, so I will stay away from Ebay and spend the extra money with Precision.
I think other mechanical or electrical parts from LMC are OK. I once bought a second battery tray from them years ago for my dual start battery setup and it was AC Delco. I just installed their power window relay upgrade kit and it seems to be working OK, although the length of some of their wires was about 2 feet too short. That relay kit install was my first attempt at electrical soldering (based on their demo video on YouTube.) I learned that like sweating copper pipe you need just a light coating of flux - too much flux prevents the solder from adhering to the wire.
tucsonjwt is offline   Reply With Quote
Old 10-01-2018, 07:50 PM   #21
olrosa
olrosa's Avatar
Precision Replacement Parts hands down!
olrosa is offline   Reply With Quote
Old 10-05-2018, 11:42 AM   #22
oldtimer1959
Much of the weatherstrip I received from Rubber the Right Way for my truck was made by precision. It was excellent. RTRW heavily discounted the parts so I got a really good deal.
