09-09-2017, 06:54 PM | #1 |
Front drum anchor bolt
I need the front drum anchor bolt that holds cylinder and springs. Any place to buy one? 1968 chevy c10
09-09-2017, 07:28 PM | #2 |
Re: Front drum anchor bolt
How did you remove it? My driver side will not budge, heat pb blaster, impact,and breaker bar failed for me
09-09-2017, 07:49 PM | #3 |
Moderator
I'm converting my drums to disc, starting tomorrow...
You can have one of the ones currently on my truck...67 C 10...so long as I can get it out. I will pm you tomorrow after I get it out... |
09-09-2017, 08:09 PM | #4 |
Mine was driver side too. Man I had to cut the nipple off so could get a better grip. That didn't work so I had to cut the brake cylinder off and then cut the piece that was behind brake cylinder. It came out easy after that.
09-09-2017, 08:10 PM | #5 |
Thanks I would appreciate it very much. I will buy it from you.
09-10-2017, 11:50 AM | #6 |
Moderator
Have the anchor pin and lock plate out and cleaned up for you.
Pm me to arrange shipping. Suggest best to wait until IRMA has passed...as I see you are in FL... Stay safe mate... |
09-10-2017, 12:33 PM | #7 |
Thanks brother I appreciate it. I sent u my address. Let me know what I owe you
09-11-2017, 02:30 PM | #8 |
Carefully heat it with a torch, and melt a little candle wax into it while tapping on it. Then hit it with the impact again. This is an old gear head tech tip that hasn't failed me yet.
09-11-2017, 02:40 PM | #9 |
Moderator
I have had much success using an 1 1/8" deep impact socket over the bolt, smacking the end of the socket with a 5lb hammer, then using an electric 1/2" impact gun...
If it doesn't come out, I usually try tightening it, then trying the reverse direction...have removed probably 100 this way... "Fire24"...parts are ready to ship, just waiting on IRMA to finish her run... |
09-11-2017, 02:58 PM | #10 |
Wax eh?
Is the timing of impact important? -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
09-11-2017, 03:01 PM | #11 |
Moderator
The smack on the deep socket is to loosen any rust within the threads...
The impact saves many a skinned knuckle...trust me... Timing of impact...not important... |
