Old 09-16-2017, 10:59 PM   #1
hollywood_35
1983 C30 rear end is toast, need help
Last summer I bought a 1983 3+3 C30 to steal the 454 and SM465 for my 81 shortbox. I didn't end up using it, but started to slowly fix the C30 instead. I just recently rebuilt the quadrajet, got it running, and went to hook up the driveshaft. It's been disconnected since I bought it. Well the pinion on the rear end is junk. It moves in and out a lot and has a ton of play. I was wondering if anyone has some resources or schematics to help me get this thing rebuilt. I know the proper thing to do would be to take it to a driveline shop to get it fixed up, but this truck is pretty much worthless at this point so I might as well just do it myself.
hollywood_35 is offline   Reply With Quote
Old 09-16-2017, 11:01 PM   #2
hollywood_35
Re: 1983 C30 rear end is toast, need help
https://www.youtube.com/watch?v=TmOQiZXsm3w
Old 09-16-2017, 11:33 PM   #3
wilkin250r
wilkin250r's Avatar
Setting up a rear differential is deceptively difficult.
With relatively few components, it seems simple on the surface. You've got a pinion gear and bearings, a ring gear and bolts, the differential housing and spider gears, and a few shims. How hard can 4 moving parts really be, right?
The problem is that ALL your power moves through those few components. So the setup and clearances to fit everything together have to be SO exact, it really is probably best left to a professional.
Yes, you could attempt to do it yourself. But learning to rebuild an axle by reading tutorials and watching videos will eat six hours at least, then another six in wrench time when you actually start rebuilding your own (less with practice, but this is your first), $250 for gears, plus another $200 for a rebuild kit, and that's assuming everything else is in perfect shape, and add nearly $200 for specialty tools like an inch-lb torque wrench, micrometer and magnetic base, or more expensive if you go with a case-spreader, plus you'll need a hydraulic press for the pinion bearing.
So rebuilding your axle looks to be a minimum 12hrs, and $700, but can easily run higher depending on how much equipment you have access to, or damage inside the axle itself.
Or you can send it to a professional.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 09-16-2017, 11:38 PM   #4
hollywood_35
I get that a lot. But I don't take my vehicles to shops. I'm a tradesman and a mechanical engineering student who designs, fabricates, and tunes race cars from scratch, so if I can't handle a rear end rebuild on an old pickup I should probably just throw in the towel. I've got all the tools required to do it, I'm just looking for some resources to get the ball rolling on this.
Old 09-17-2017, 05:45 PM   #5
v30crewcab
v30crewcab's Avatar
14 bolt rears are dirt simple to work on.
http://www.pirate4x4.com/tech/billav...4b_Gear_Setup/
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 09-17-2017, 05:50 PM   #6
obijuan
find another and swap it in.
1985 k5 396/nv4500/203/205 d60/d70 4.56 42 sx2
1991 V3500 350/4l80/205 60/14 4.10 35 toyos.
obijuan is offline   Reply With Quote
