09-18-2017, 08:56 PM | #1 |
IS this an automatic?
I don't know if this is an automatic or three speed. I would love for it to be automatic. I can't pull the handle backwards at all.
09-18-2017, 10:22 PM | #2 | |
But Found Her 25yrs Later!
Re: IS this an automatic?
If it was a column shift manual, it wouldn't have that gear selector pointer. Also, there would be more linkage attachment locations available. Yours only has the one. . This thread might help some: http://67-72chevytrucks.com/vboard/s...d.php?t=425991
09-18-2017, 10:27 PM | #3 |
Here's another thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=478964
09-18-2017, 11:56 PM | #4 |
Looks like a auto.
09-19-2017, 12:04 AM | #5 |
Well that seems like great news. I was going to order an ididit column. Would this column work with my 4l60E shift pattern then?
09-19-2017, 12:08 AM | #6 |
You can make it work you will have another gear. You can sell it if you want. Thay bring good money.
09-19-2017, 12:43 AM | #7 |
60-66 Nut
It will work, but without reworking the column you likely won't be able to manually shift into 1st gear.
09-19-2017, 09:21 AM | #8 |
Yes it's and auto!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
09-19-2017, 09:36 AM | #9 |
Captianfab, do you really need to manually shift into first, it is just going to be a fun driver, I never use Manuel 1st unless I'm either in the Colorado mountains or have a 4x4 to which neither will this truck be doing. Opinions?
09-19-2017, 11:23 AM | #10 |
When you hook it all up you need to know where drive will be. Then just put it in drive and go. I have a 1961 impala with a pig trans. I am putting a th 350 in it now. So i know exactly what to do.
09-20-2017, 12:04 AM | #11 |
60-66 Nut
No, you don't have to be able to manually shift into 1st. Just making you aware of the results of using that column as it is.
09-20-2017, 12:15 AM | #12 |
That is for a power guide transmission. You may be able to convert your columb to a three speed automatic by using a shift tube out of a 67 to 72 columb that is from a three speed automatic. It will need to be modified some, shortened. The newer columns are much easier to find. Plan to try this but have not done yet to see changes needed.
Les |
09-20-2017, 12:30 AM | #13 |
60-66 Nut
An original Powerglide column will work with a 3 speed auto trans and still be able to shift into 1st. Granted some of that ability may be due to a worn column from 50+ years of use.
09-20-2017, 11:43 AM | #14 |
Do you have everything else such as the indicator lens?
09-20-2017, 12:49 PM | #15 |
I will also maybe change my lens to.
