Old 09-25-2017, 07:50 PM   #1
Joe Z
Steering box questions.
I have an 81' c10 that has power steering and non boosted breaks. I'm thinking about swapping the steering box to a manual gear box and deleting power steering because I like the simplicity. The manual gearbox is hard to find around here and I was wondering if anyone could tell me if they are a direct swap onto the later model trucks? Thanks.
Joe Z is offline   Reply With Quote
Old 09-25-2017, 07:53 PM   #2
Bobby Pootz
Bobby Pootz's Avatar
Re: Steering box questions.
I have never heard of someone wanting to convert to manual steering. Are you sure? I'm sure you are, but I just drove my sons beater 80's ranger with no power steering and I almost crashed the damn thing.
I'm positive you would be able to find someone to swap with you if it was compatible.
My two cents
Bobby Pootz is offline   Reply With Quote
Old 09-25-2017, 08:08 PM   #3
Joe Z
Trust me I'm sure. I've had a few manual steering trucks and cars. Even a 40 foot greyhound from the 50's. The main reason why though is I put a 66' inline six 250 in the truck and have an extremely rigged bracket for the pump that's just begging to fail and I figure a good steering box is better than trying to make another bracket, probably easier to find too. Not to many 60's trucks with power steering.
Old 09-25-2017, 08:36 PM   #4
Bobby Pootz
That totally makes sense now, never mind me butting in... Didn't realize the motor swap.
Old 09-25-2017, 08:40 PM   #5
Joe Z
No problem, not many people would guess that swap. Most people stick to the v8's.
Old 09-26-2017, 06:13 AM   #6
D13
D13's Avatar
My 81 3/4 ton 2wd and my 77 1/2 ton 2wd are both manual steering. The 77 has manual brakes and the 87 has power, could not delete the power assist on the heavier brake system.
Both 250's and 3 sped manual trans and pretty much no other options.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 09-26-2017, 06:45 PM   #7
Joe Z
Thanks, do you know if the steering boxes are the same for both of those years? I just want to make sure they didn't change them up somewhere along the line.
Old 09-28-2017, 12:28 AM   #8
Pontiac1976
Pontiac1976's Avatar
Manual steering box-rebuilt #76-930 (73-86) 2WD Classic Parts.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 09-28-2017, 09:02 AM   #9
Jeff's bowtie's
You can use a manual box off a 68-87 C/10-30 it will bolt right on
Jeff's bowtie's is offline   Reply With Quote
Old 09-29-2017, 07:51 PM   #10
Joe Z
Thanks for the help. I'll have to track one down now.
Old 09-29-2017, 10:03 PM   #11
73kay
Shoot, I just happen to be switching to power steering this weekend and in fact I'm driving my truck up to Virginia here soon, so let me know if you can find a manual steering box.
Andrew
1953 3100 292 T5
1985 K5 Blazer 350 700R4 208
73kay is offline   Reply With Quote
