Old 09-28-2017, 07:12 PM   #1
ToyWrecker
1949 frame swap
Anyone ever swapped a 1948 thru 1954 Chevy 2 ton cab and front sheet metal onto a 67-72 Chevrolet 1 ton dually frame. maybe have suggestions and pictures. My main concern is the wide front track. Will make the wheels stick outside the fenders and look weird. I need a 1 ton dually to pull my horse trailer and 18 car trailer. THANKS !
ToyWrecker is offline   Reply With Quote
Old 09-28-2017, 07:40 PM   #2
mongocanfly
mongocanfly's Avatar
Re: 1949 frame swap
"18 car trailer"???...your gonna need more than a dually to pull that..
as for a late model dually under a 2 ton AD cab its been done...but you might be better off with a TF or early to mid 60s big truck..
Old 09-28-2017, 07:54 PM   #3
ToyWrecker
Re: 1949 frame swap
Sorry 18-foot one car hauler trailer. I guess you have seen a car hauler trailer that can haul 18 cars.
Old 09-28-2017, 07:58 PM   #4
mongocanfly
Re: 1949 frame swap
haha...yep most are pulled with a kenworth...
I used to have some saved pics of the largs ADs on 1ton chassis but I don't anymore..
Old 10-01-2017, 02:19 PM   #5
4544speed
4544speed's Avatar
Re: 1949 frame swap
Here is you one close. Newer frame but looks like a good start.
https://houston.craigslist.org/cto/d...293617701.html
4544speed is offline   Reply With Quote
Old 10-01-2017, 02:52 PM   #6
joedoh
joedoh's Avatar
Re: 1949 frame swap
4545 speed is right, that 51 in houston is miles ahead of starting one yourself.
Old 10-04-2017, 02:03 AM   #7
ToyWrecker
Re: 1949 frame swap
Might have been, But it has been sold for a week now. So back to the drawing board.
Old 10-05-2017, 11:24 AM   #8
nicke
nicke's Avatar
Re: 1949 frame swap
I'm in the middle of a similar project now. Swapping a '51 1 ton dually to the chassis of a 82 GMC 1 ton dually, for the purpose of having a nice tow rig.
I even have a '50 2 ton as well, which as you know, is slightly wider across the front fenders.
My measurements show that it should line up pretty well, and result in a scenario where the wheels WONT stick out beyond the fenders, especially if using the 2 ton body.
My advice is get your measurement from the 67-72 chassis you want to use, (maybe outside of front tire to outside of other front tire) and see how that lines up with the fender width of the two ton truck, which is 74 7/8" front outside of front fender to outside of front fender.
I hope that helps.
-Nick
1965 Impala SS project Page.
My Wheels
Classic Nation
My classic car videos
nicke is offline   Reply With Quote
Old 10-05-2017, 04:09 PM   #9
mr48chev
mr48chev's Avatar
Re: 1949 frame swap
Ad me to this group, I have a 51 4000 series truck and a 77 1 ton dualie chassis that I hauled home after a guy gave it to me and loaded it minus the rear axle.
I'm still deciding if I want to put the one ton suspension on the 1-1/2 ton frame or swap the cab over to the other frame so I am interested. I have the title to the 77 frame and the 51 so paperwork isn't an issue. It's about the same amount of work either way.
My ongoing truck projects:
Old 10-05-2017, 04:45 PM   #10
nicke
nicke's Avatar
Re: 1949 frame swap
I'll be starting a build thread soon documenting my swap.
Feel free to pm me with any specific questions too.
-Nick
My Wheels
Classic Nation
Old 10-05-2017, 06:06 PM   #11
ToyWrecker
Re: 1949 frame swap
Wow thanks, guys. For a while there I thought I was the only one taking on a swap like this. Seems like most are going with the stock original frame that the truck came with. Or going to a s-10 . I have the original frame but its stiff and ruff not that a 70 dually is an easy ride. But better steering, suspension, and better brakes/later model make for a better truck. A S-10 swap would be great for a driver, but not for a combination work/hauler/ tow truck.
THANKS !
Old 10-07-2017, 12:08 PM   #12
4544speed
4544speed's Avatar
Re: 1949 frame swap
I keep looking at some kind of swap like this also. I have a 2000 dodge diesel that only has 180K miles to use as a donor. It is great shape but wife will not ride in it so I might as well make her REALLY HATE it. I just don't want that 6 banger diesel setting next to me. Kinda wish I had a V8.
Old 10-08-2017, 09:40 AM   #13
Matt_50
Re: 1949 frame swap
I couldn't figure out how to copy the page. Do a search here for....52 pickup on 77 frame. By...slydogg76...
It should work for you pretty well. 2 ton is a little bigger than the 3100s and i just put the front suspension from a c10 into my 50. For me I need to change the wheels and tires. I'm gonna get factory looking wheels that are thinner. Wheels will suck in some and it'll have the right look. The stance now is a little tall but should look good on your 2 ton. I'm not as worried for mine, no car hauler here. If I ever get one of the bigger versions like yours, I'd still go for the c10 swap route.
Matt_50 is offline   Reply With Quote
Old 10-08-2017, 02:18 PM   #14
mongocanfly
Re: 1949 frame swap
matt...here ya go...http://67-72chevytrucks.com/vboard/s...d.php?t=600843
Old 10-09-2017, 08:28 PM   #15
ToyWrecker
Re: 1949 frame swap
That's a nice 1950 build Matt and mongocanfly read the complete build. Using the C-10.
Thanks ! But I was talking about ideas on using a one ton dually frame. It's a lot different than a c_10. even the track. And even I could adopt or install a 1/2 t c10 suspension. The wheels will quickly give it away. Troopers here in Texas will pull you over or check you out at weighing stations if they think you're overloaded. Never had it done. but seen it happen a lot. A trooper putting on coveralls and crawling under trucks. It will not fly. But It will give you a heavy ticket. And I happen to live in the capital, so Troopers seem like there on every block waiting for you to mess up. Yep the great state of Texas.
Old 10-09-2017, 08:56 PM   #16
mongocanfly
Re: 1949 frame swap
sure wouldn't have thought Texas was that bad...
