10-01-2017, 10:35 AM | #326 |
Re: What did you do to your truck today part IV
started to install new uppers and lower ball joints, next will be tie rod and linkage
10-01-2017, 10:51 AM | #327 |
Painted some parts black and prepping for bags
Just waiting for later model lca u-bolts. |
10-10-2017, 12:11 AM | #328 |
Been sand blasting....
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
10-10-2017, 10:34 AM | #329 |
"I" did not do anything, BUT my wife decided to use the bed to hold 3,000+ Easter eggs for this springs Easter egg hunt for our local community.........Rascally rabbit.....
http://s1299.photobucket.com/user/jb...23904108567829 |
10-10-2017, 12:17 PM | #330 |
Installed the Wide ride front end from No Limit Engineering,..
All I can say is wow, Rob builds nice stuff. |
10-10-2017, 06:19 PM | #331 |
Yeah howdy, Easter Bunny Crewzin in STYLE!
10-14-2017, 11:39 PM | #332 |
10-15-2017, 10:47 AM | #333 |
Finally got the control arms off. Now to try to get them apart.
10-18-2017, 11:24 AM | #334 |
Couple days late, but got the inner fenders and core support primed in. Love having a sand blaster.
10-22-2017, 08:31 PM | #335 |
filled random holes in the floor
10-23-2017, 03:00 PM | #336 |
Working on small stuff. Really happy with how the pedals turned out. Matches the lokar pedal nicely.
10-23-2017, 03:11 PM | #337 | |
Cruzzzn' Vet
10-23-2017, 03:43 PM | #338 |
I've been slowly getting the little bits done on the engine compartment.
I hand threaded the stainless wire through the existing staple holes on the inner fender seals. That was brutal. I got all of the wiring cleaned up and done, got the radiator support in and the radiator. I got the carburetor hooked up and tried to fire it up, and it cranked and wanted to start, but there was fuel leaking out on the top of the throttle body. So off came the carburetor. |
10-23-2017, 09:37 PM | #339 |
Got the pedal mounted and adjusted in today.
10-23-2017, 10:15 PM | #340 |
Moderator
10-24-2017, 11:12 AM | #341 |
10-26-2017, 09:42 AM | #342 |
I am in the process of sanding down the bed. The wood is good but the previous owner never stained/sealed it so it looks weathered.
What's the easiest way to get all the grey muck off? I tried sanding with 40 grit but it was tedious for the small amount that it got off.
1965 Chevy C-10 350 V8 2003 GMC Sierra Crew Cab 6.0L 4x4 |
10-26-2017, 11:56 AM | #343 |
Started building new front upper shock mounts for the 61. Kind of copied the old broken ones but with a few mods for more strength. Will post pics when I get then finished.
Nick 1961 Apache short stepside 4X4 SBW 348/4 speed 1960 Apache C-20 long fleet custom cab BBW 283/4 Speed 1967 rust bucket Olds Cutlass with a 455 1972 GMC K-15 350/4 speed long fleet |
10-26-2017, 11:59 AM | #344 |
How nice do you want to get it. I would take the wood out maybe you some kind of paint stripper.
10-26-2017, 07:00 PM | #345 | |
10-28-2017, 09:07 PM | #346 |
3 weeks back or so the truck started running rough at low idle, checking into it we discovered a broken exhaust spring. These were the original springs and we decided to change them all to new ones, with the heads in place. We started on the truck at about 8 am and by using a air pressure manifold, we were able to use air pressure to keep the valves up while removing the springs.
Took about 6 hours, the worse springs to get to were cylinder 6, because it's almost directly under the heater core. Instead of using a spring compressor, we used an open end wrench to press down on the springs so we could remove the keepers. Glad this job is over, took about another hour to set the lifter clearance and tune in the carb.
http://s1299.photobucket.com/user/jb...23904108567829 Last edited by jbgroby; 11-03-2017 at 10:12 AM. |
11-03-2017, 09:15 AM | #347 |
pulled all the window trim pieces and my glove box door out to repaint them all.
I have to stop using my Suburban to move. It's getting very tiring sanding and fixing the scratches for repaint. This is the last time and trying to get the interior done before next Saturday for the Walkin' on Main Car Show put on by the Mingus Union High School Auto Club. |
11-03-2017, 09:59 AM | #348 |
It's Better With Nitro
Had some pin striping done on the rear of the cab and leading edge of the hood...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
11-03-2017, 10:22 AM | #349 |
1962 C-10
Very cool!!
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
11-03-2017, 01:45 PM | #350 |
