Old 10-03-2017, 07:28 PM   #26
71BUCKET
Re: Sound Deadener and Heat Suppression
Used damplifier on mine. Black backing. Blended in well
71BUCKET is offline   Reply With Quote
Old 10-03-2017, 07:37 PM   #27
Mr Handy
Mr Handy's Avatar
I went a different route and sprayed in lizard skin. I liked the fact that it seals and protects the metal from moisture. I sprayed two coats of the sound deadener inside the cab on the floor and up the back as well as on the headliner area. Also sprayed a coat in both sides of the floor (inside and outside) up the back wall and on the headliner area. then painted over everything. so far I am really happy with it, but i have just been around the block. I cant wait to get the carpet in, but it was weird to drive around and not hear any rattles.
Mr Handy is offline   Reply With Quote
Old 10-03-2017, 08:38 PM   #28
bill3rail
bill3rail's Avatar
Still confused here. There seems to be no consensus on brands or price.
First off, I am cheap! Except for when it comes to my comfort level driving. I need to be happy there. And sound deadener would make my cheap audio system sound better.
Does anyone know how much we need for a standard cab 67-72?
If I could buy just enough for what I need, there would be no extra for me to spend my cash on.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 10-03-2017, 09:12 PM   #29
Rex'69
Rex'69 is offline   Reply With Quote
Old 10-04-2017, 03:27 AM   #30
un4gvn!
un4gvn!'s Avatar
I used the stuff from Lowes and it works great. I have new bucket seats and carpet. On a hot day with the windows up, I open the door and all I smell is new seats and carpet. Nothing is melting or other smells. I saved a bundle.
un4gvn! is offline   Reply With Quote
Old 10-04-2017, 08:34 AM   #31
JMC1965
JMC1965's Avatar
Undoubtedly I overspent on this....but I used Second Skin. Damplifier Pro and Luxury Liner Pro.
Very quiet.
the Luxury Liner pro also blocks heat
http://store.secondskinaudio.com
JMC1965
1967 C20 LWB
  • 350 (ATK-HP32) / FiTech EFI
  • 4L60e / 4 wheel disc brakes
  • 20" American Racing VN327 & 245/50/20 Michelin
JMC1965 is offline   Reply With Quote
Old 10-04-2017, 01:04 PM   #32
Jcfcamaro
Jcfcamaro's Avatar
I used peal +seal from Lowe's in my 67 camaro it worked great. I just overlapped the seams by a 1/2 in. Been in the car 6yrs and no problems. My new carpet had the factory style jute padding under it. Made my car real quite inside. My buddy had a piece of dynamat we compared it to peal and seal and it looked the same and smelled the same only the peal and seal was a hair thicker. I guess it all depends on how much you want to spend.
Jcfcamaro is offline   Reply With Quote
Old 10-08-2017, 04:22 PM   #33
forestb
forestb's Avatar
Has anyone tried stp sound deadening I got some for free but I didn’t know where I should use it
forestb is offline   Reply With Quote
Old 10-08-2017, 09:17 PM   #34
weq92f
weq92f's Avatar
The peel-n-seal and other less expensive alternatives are not heat barriers. They are good panel dampers ( sound ) but really do nothing for the heat.
I used Tru-Max Insulator Mats part number: TRU-30000-12406. This is a 28 dollar 48" by 72" roll of effective insulation ( heat/sound ) with foil facing on both sides. I put it down with 3m spray adhesive against the peel-n-seal. Used aluminum tape to seal the seams and went as high up the firewall as possible with the stuff.
Works as advertised.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 10-09-2017, 05:03 AM   #35
LT7A
Except for the non-heat-conducting qualities of the rubberized asphalt and the reflective qualities of the foil backing.
Old 10-09-2017, 12:13 PM   #36
weq92f
weq92f's Avatar
OK, maybe the stuff isn't completely useless for the heat My experience with it here in the Texas summer has been less that stellar. Big difference was felt after installing the Tru-Max barrier and mass-backed carpet over top of that.
-klb
Old 10-09-2017, 01:34 PM   #37
CastIron
CastIron's Avatar
I've used some peel and seal type stuff in a more modern car to see how much difference it made. It didn't seem to make that much difference, but that car already had sound deadener from the factory. I imagine it would make more difference on an old truck. I did have a few small sheets of dynamat I put on my C1500 a few years ago, but that didn't seem to do much either. My eventual goal is to pull the original seat and rubber mat from my truck and use dynamat in a larger area then install an ACC carpet with mass backing. I will also put more dynamat in the doors. I think that will bring down the noise level enough to cruise quietly at highway speeds.
CastIron is offline   Reply With Quote
Old 10-09-2017, 01:52 PM   #38
Steve Cole
NC John is right. This Fat Mat, peel and seal and all that other stuff mentioned is only for rattles and to keep things from vibrating. It does very little in the way of blocking out road noise. Like John said, the Dynamat stuff is only part of the complete package. What you really need is some "Mass Loaded Vinyl" and it needs to be separated from the Dynamat stuff with a thin layer of some type of padding.
Read this article and you will be a sound blocking genius! ----> www.sounddeadenershowdown.com
Steve Cole is offline   Reply With Quote
Old 10-10-2017, 01:48 PM   #39
skinnan
Originally Posted by chasinhiway View Post
I know there are cheaper versions but I used Dynamat extreme and am VERY pleased with the results. You can listen to the radio and carry on a conversation while running 70 mph down the road.
you need a better radio...
skinnan is offline   Reply With Quote
Old 10-10-2017, 02:22 PM   #40
cleszkie
cleszkie's Avatar
In my Blazer, I lined the entire tub and inside my doors with Fat Mat. Worked great at sound deadening with carpet over top. But not so much with heat reduction inside the Blazer. To solve the heat issue, I lined a portion of the engine compartment side of the firewall with Kevlar heat shielding, and ran this all the way under the tranny tunnel over the transmission. I also added more Kevlar heat shielding on the underside of the bed floor between the mufflers and the bed floor. This heat shielding greatly reduced the radiant heat that was coming through the firewall and up through the floor. No more warm/hot floor, and the A/C works much better without having to fight the radiant heat.
cleszkie is offline   Reply With Quote
Old 10-10-2017, 05:59 PM   #41
JMC1965
JMC1965's Avatar
kevlar heat shielding?....no heat and bullet proof?
JMC1965
1967 C20 LWB
Old 10-11-2017, 06:06 PM   #42
cleszkie
cleszkie's Avatar
All of the off-the shelf heat shield pads I have found and used have some degree of Kevlar reinforcement. Not meant to act as a bullet stopper or scatter shield, but just to provide longevity to the pad in its harsh environments under the Blazer. A little spendy, but well worth the results.
Old 10-11-2017, 11:34 PM   #43
allchevy58
allchevy58's Avatar
I've used Peel N Seal on four of my vehicles and it made a difference. On the 72 K20, did the fuel tank too, can't hear the gas slashing around anymore. Hasn't come loose or smelt at all. Just bought another roll online with free shipping from BUYMBS.com in Ohio, cheaper than Lowes. It's roofing material so it shouldn't melt.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 10-12-2017, 12:26 PM   #44
azle
Allchevy how thick is it and which one did you use. There are a bunch on that site.
Azle
azle is offline   Reply With Quote
Old 10-12-2017, 11:40 PM   #45
allchevy58
allchevy58's Avatar
Azle
I purchased the MFM #50036, 36" wide, 45 mills and 33'6" roll.
Old 10-16-2017, 12:39 PM   #46
JMC1965
JMC1965's Avatar
cleszkie...do you have pics of it installed?...you got me thinking about it
JMC1965
1967 C20 LWB
Old 10-17-2017, 12:33 AM   #47
allchevy58
allchevy58's Avatar
No, thought I took pictures when I did my 58 this summer but guess I didn't. I did the 72 about three years ago, pictures long gone. Sorry
Old 12-30-2021, 11:39 AM   #48
Larry S
Larry S's Avatar
The peel & seal Im seeing at lowes these days is only 6”wide x 25’ long. Is this the product folks are using that are opting for peel & seal?
Larry S is offline   Reply With Quote
Old 12-30-2021, 12:28 PM   #49
Big Kev-O
Big Kev-O's Avatar
Yes, thats the stuff. It work ok but I suggest you look into KilMat. It is very affordable and it definatly works better than that peel & seal. Your truck looks nice, use the right stuff.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 12-30-2021, 01:41 PM   #50
Larry S
Larry S's Avatar
10-4. Thanks. I was just looking at options, now. Im thinking Im probably going with a nice, full rubber floor mat. Im planning to use truck as a driver. Im not going with carpet. Probably wont get it painted for a couple years.
