Old 05-06-2017, 12:12 AM   #101
milner
milner's Avatar
Re: C10 Goldilocks
My new favorite truck! Sweet build!
355,vortec heads, Doug Herbert cam, Performer intake, 750 Holley, Hooker Comps, 2 1/2 duals w/Aero Chambers, 2500 stall and 3.73 posi.
milner is offline   Reply With Quote
Old 06-02-2017, 09:11 AM   #102
Phill0406
Phill0406's Avatar
Re: C10 Goldilocks
Haven't checked in with you guys in a while. Little slower progress than normal lately. Finally got the firewall fitted into place, finished welding up the top of the wire channel, cut the trans cover out and put in a high hump, put the cab on the frame (temporarily) and that's pretty much it. I have to move shops since the building I am currently in is selling. The new spot I'm going to has significantly less room but it'll do! Some pictures.
The death wheel caught a piece of the carpet cutting out the low hump and the disc exploded upon impact. No guard too Don't mind the mess.
Had to slap the rest of the body panels on just to get a wiff of the final product.
My two trucks, one went up the other not so much…
Moving all my crap this weekend, some more welding on the cab tuesday. Maybe do some break lines or something next weekend. Who knows.
Phill
68 Anniversary build - LS swap & Porterbuilt
Instagram @fourdoorphill
Phill0406 is offline   Reply With Quote
Old 06-02-2017, 10:48 AM   #103
hewittca
hewittca's Avatar
Re: C10 Goldilocks
Lookin' so good. I like the mockup, it helps with inspiration.
(Word to the wise, I would edit your post to remove the stickers for sale or else the thread will get locked real quick since you're not a premium member.)
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 06-02-2017, 10:56 AM   #104
Phill0406
Phill0406's Avatar
Re: C10 Goldilocks
Yikes, good call!
Phill
Old 06-02-2017, 04:06 PM   #105
knomadd
knomadd's Avatar
Re: C10 Goldilocks
I love the sticker in the back window Nice work too!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 06-02-2017, 04:42 PM   #106
MMcMasters
MMcMasters's Avatar
Re: C10 Goldilocks
sorry to hear your losing that great big work area but the truck is looking killer!
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
Old 08-17-2017, 07:51 AM   #107
Phill0406
Phill0406's Avatar
Re: C10 Goldilocks
I need to go through all my photos and update you guys with some goodies!
I've been working, getting it done. Had a lull for a month or two but the firewall got finished, I shaved and seam sealed up everything including the AC and heat holes, got a driveshaft, figured out why my motor wouldn't turn, new 3.73 gears, did the rear brake lines, mounted the cab, started setting up the air ride, made some bed mount brackets, got a radiator from RnD (thanks sparky!), put in the porterbuilt gas assisted hood hinges... all the little things you didn't think would slow you down. I did however manage to get sponsored by Air Lift which is amazing. The truck will be running full 3H management, dual Viar 444c compressors, 5 gallon seamless tank (had it powder coated black) and SMC Water traps. Hoping to have that done within a week. Been waking up at 5am to get some extra time in on the truck.
My goal is driving it in a month or so. Actually let me rephrase that, I WILL be driving it in a month or so...
When I have some time to come up for some air I'll add more photos for you guys.
Phill
Old 08-17-2017, 07:56 AM   #108
GR8-68
GR8-68's Avatar
Re: C10 Goldilocks
An awesome build for sure, love the mock up also. I have had my cab and bed off and on numerous times checking fit and seeing how things look.
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 10-03-2017, 12:47 PM   #109
Basketcase889
Basketcase889's Avatar
Re: C10 Goldilocks
time for an update Phil! its running and made its first trip and nobody here knows that yet!!
Basketcase889 is offline   Reply With Quote
Old 10-07-2017, 05:46 PM   #110
Phill0406
Phill0406's Avatar
Re: C10 Goldilocks
hah! It's true, I finally got the truck up and running. I had an absolute mad dash on it for a few weeks trying to get everything done. The RND radiator I bought unfortunately had a really bad leak in it, they're trying to blame me for it for using radiator zip ties without the rubber backing even though the leak is 6 inches away from where I used them. Ended up getting a griffin and tapping my water pump for the steam port. Had a leak in just about every fluid line you could think of. My rear lights weren't getting any power so that was a fun time to fix, but all in all - it drives. Still having cooling issues where the radiator isn't getting the full flow. The passenger side is ice cold and the driver side is boiling hot blowing steam out of the overflow. Not sure if the radiator baffle is broken (same side inlet and outlet) or if I have an air pocket or if my water pump is **** but I'll figure it out. Haven't had time to finish putting the hood on (need to weld the brackets onto it) or do the bed floor.... or even bolt in the bench seat or clean up anything. I had a deadline for last Thursday and justtt barely made it.
Had the exhaust done with 2.5" and flowmaster 10s. Sounds great.
Trailerd it down to Maryland for a weekend car show with my buddies. Got to drag my frame down the costal highway which felt like a million bucks after all the hard work I put into it.
Some exhaust clips.
https://www.youtube.com/watch?v=ttAnt-39Bl0
https://www.youtube.com/watch?v=tMMSGDdUV60
Phill
Old 10-07-2017, 06:00 PM   #111
builtbyKane
builtbyKane's Avatar
Re: C10 Goldilocks
Way cool
builtbyKane is offline   Reply With Quote
Old 10-08-2017, 04:32 PM   #112
rusty76
rusty76's Avatar
Re: C10 Goldilocks
Truck looks amazing.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 10-23-2017, 12:54 PM   #113
Phill0406
Phill0406's Avatar
Re: C10 Goldilocks
Thoughts of a turbo been running through my mind lately...
Phill
Old 10-23-2017, 01:55 PM   #114
builtbyKane
Re: C10 Goldilocks
Get that dude on the road and reliable then decide on the turbo. But that's just my 2˘ of snowballed projects
Old 10-23-2017, 08:43 PM   #115
knomadd
knomadd's Avatar
Re: C10 Goldilocks
What he said!
-Duane
Old 10-24-2017, 08:35 AM   #116
hewittca
hewittca's Avatar
Re: C10 Goldilocks
still making great progress. I like the pic of it sitting in the leaves.
Old 10-24-2017, 11:03 AM   #117
gringoloco
A guy with a truck
gringoloco's Avatar
Re: C10 Goldilocks
Sexy pic! Turbos are sexy too... you’re not the only one having these thoughts
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-29-2017, 11:35 PM   #118
Hendo
Re: C10 Goldilocks
Just went through this whole thread. Loving it so far. Great looking truck. The gold and white patina is awesome looking sitting on the ground.
Hendo is offline   Reply With Quote
Old 11-25-2017, 03:37 PM   #119
Phill0406
Phill0406's Avatar
Re: C10 Goldilocks
Haven't done much of anything to the truck in the last few months, just been cruising it. The overheating issue was just a big air pocket, bled and burped the system and it's ice cold now. In this New England fall weather I'm not even needing to use my fan.
Going to take it out to shoot some photos of it later today but then it's back into the garage. Finally going to put the hood on and make some bed mounts. I need to see if the hood will clear the engine covers.
Bought a wilwood MC yesterday with the good deals AZ pro had going on, going to go with manual brakes. I don't like the gushy pedal that the booster is giving me. Gonna pull the motor and redo the body work on the firewall and likely paint it gold, BTR stage 4 cam, paint the engine black, maybe some new heads, put the height sensors on the air ride. A lot of work to do.
Phill
Old 12-03-2017, 05:04 PM   #120
04ls1gto
Re: C10 Goldilocks
Truck looks great, where in RI are you I'm in Portsmouth
04ls1gto is offline   Reply With Quote
Old 12-03-2017, 06:41 PM   #121
LakeAnna
LakeAnna's Avatar
Re: C10 Goldilocks
Man that build is bad ass! Nice work.
Chris
72 RESTO
http://67-72chevytrucks.com/vboard/s...d.php?t=501870
LakeAnna is offline   Reply With Quote
Old 12-04-2017, 11:26 PM   #122
rustytruck50
rustytruck50's Avatar
Re: C10 Goldilocks
Originally Posted by lakeanna View Post
man that build is bad ass! Nice work.
x2!!!!
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 12-05-2017, 08:37 PM   #123
Phill0406
Phill0406's Avatar
Re: C10 Goldilocks
Man, I wish I was still in lil rhody. I was in Smithfield but just moved over the border back to MA - Hopedale. Any other c10s down there?
Phill
Old 02-11-2018, 11:15 PM   #124
Phill0406
Phill0406's Avatar
Re: C10 Goldilocks
Tore the truck apart - making things a little tidier. First up was putting the floor back in the bed. Holy crap was this a lot of work. Capped off some 1.5" eighth wall box tubing with a plate with a hole and a grade 8 nut welded on the inside, built the frame around that, put plates on the ends with two holes to bolt to the bed side then painted it with chassis paint. The frame I built bolts into the stock location using half inch bolts - worked like a charm. The extra brace in the front is for the exhaust hangers to bolt to. Then I recessed the under side of the floor so it would fit snug on the frame, pressure washed and then undercoated it and flopped it in. The wheel tubs got cut down and patched up, undercoated as well and then I did a vinegar/hydrogen peroxide/salt mixture to make them rust a little. Color matches the carriage bolts and viola. A tip for anyone doing this... it's way easier to take one side of the bed off to get the floor in than it is to try to shoe horn the thing into place. It takes a few minutes longer but is so much easier.
Just need to cut the hole for the flush mount fuel filler and it'll be done. Now it's onto the fire wall. There are a few holes I want to shave and then give my best shot at actual body work instead of a tube of seam sealer and spray paint. I have an April 31st deadline for a show, a lot more work to do.
Phill
Old 02-12-2018, 09:42 AM   #125
hewittca
hewittca's Avatar
Re: C10 Goldilocks
Nice to see an update. The raised steel floor looks great! Did you have to cut the lip off the edge of the steel floor to get it to slide up between the bedsides like that? When I did mine, I ended up moving the mounting flange up the sides of the bedsides like they are connected stock because I thought the bed floor wouldn't fit and I didn't want to cut off that lip. I'm thinking now maybe I could have done it this way afterall.
