Old 04-18-2004, 05:59 PM   #1
72'BBGMCSGCC
Question bore or not to bore?
My 402BB has 66,000 origional miles and I had the block and all of the clearences checked and the machinist said I can use all standard bearings and rings,etc. and there was hardly any wear on the engine. The bearings were in unbelievable condition. I've talked with a couple of other mechanics and they said it should have been bored out just to make sure everything was done right. Do I need to have it bored or not? Thank you everyone
72'BBGMCSGCC is offline   Reply With Quote
Old 04-18-2004, 06:32 PM   #2
kwmech
If everything is to spec, I personally would not bore the block. No sense in boring if you do not have to.
Old 04-18-2004, 06:35 PM   #3
jhwkns
Registered Cruiser
jhwkns's Avatar
66k is just broke in... There should be plenty of life left there...
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 04-18-2004, 08:47 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
A quick hone job for the crosshatch pattern and go.If you bore it it will need pistons and rings in the new size.Also you will lose one more rebuild the block would be capable of.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 04-18-2004, 08:54 PM   #5
guitarornothin
RUNN over AGAIN!!!
guitarornothin's Avatar
i wouldnt if you dont have to.
67-72 TRUCKS ROCK
70 SWB shaved and a 72 front clip.and a poly tank.
Peep mirrors and a BIG BLOCK 468 in the making.
XNXNXNXNXNXNXNXNXNXNX
,/. EMAIL ME HERE!, Dont pm me please
guitarornothin is offline   Reply With Quote
Old 04-18-2004, 09:04 PM   #6
Jeepster376
Jeepster376's Avatar
Not with only 66k, if the cylinders measure OK, just hone and ring it. Bore it next time.
72 Cheyenne Super 4x4 SWB
Jeepster376 is offline   Reply With Quote
Old 04-19-2004, 09:20 AM   #7
72'BBGMCSGCC
Smile
Thanks everyone. I appreciate it.
Old 04-19-2004, 09:21 AM   #8
72'BBGMCSGCC
Question
I forgot to ask, Should I buy new pistons and rings or just rings and use the origional pistons? Thank you
Old 04-19-2004, 10:40 AM   #9
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
just for ???? if all was good, what made you tear it down in the first place?
sneakysnake is offline   Reply With Quote
Old 04-19-2004, 04:31 PM   #10
72'BBGMCSGCC
Smile
The truck is having a ground up restoration done and it had a leaking rear main and found out it had 1 bad intake valve , but that was all. What about changing the pistons?
Old 04-19-2004, 05:38 PM   #11
smitty62
smitty62's Avatar
Old pistons--new rings. Make SURE you have the cylinders honed! Sounds like you lucked out.
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
