Old 10-12-2017, 07:00 PM   #26
Drummerboy
Drummerboy's Avatar
Re: What's a good power disc brake kit?
I found this kit on Summits sit. https://www.summitracing.com/parts/ssb-a126-71
The only issue I'm seeing with it is that it says stock wheels will not fit with these rotors. Right now I'm trying to keep the 15x9 steel wheels on it. Will these not fit?
Drummerboy is offline   Reply With Quote
Old 10-12-2017, 08:34 PM   #27
chewychevy67
That is the same kit as mine. What they mean by stock wheels not working with the kit is you must have wheels that clear the calipers. The older 6 bolt rims don't. I used 15x6 from an 81 4x4 and they look stock. 6 bolt rally rims work with this kit as well.
chewychevy67 is offline   Reply With Quote
Old 10-12-2017, 08:37 PM   #28
chewychevy67
And if you require dust shields and you can fab a bit buy some gm car 67 70 shields and make a minor modification. Looks like it could have come stock!
Old 10-12-2017, 10:01 PM   #29
Drummerboy
Drummerboy's Avatar
Nice! Actually, I believe my wheels are 80's 4x4 wheels. Mine have four ears, rather than three.
Old 10-12-2017, 10:10 PM   #30
BCOWANWHEELS
sweet
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 10-12-2017, 10:16 PM   #31
Drummerboy
Drummerboy's Avatar
Will I need to change anything under the dash, such as your brake pedal?
Old 10-12-2017, 10:24 PM   #32
chewychevy67
Yep those are the same as mine. Just 8" wide and mine are 6". You don't have to change the pedals.
Old 10-18-2017, 08:04 PM   #33
Drummerboy
Drummerboy's Avatar
I think I've found a set up that will work but, I wanted to get y'alls opinion. I believe I can use the Scarebird disc kit with a stock '68 booster. Thoughts?
https://scarebird.com/index.php?rout...product_id=150
https://www.napaonline.com/en/p/NBB5473709
Old 10-18-2017, 09:04 PM   #34
BCOWANWHEELS
68 booster is drum / drum brakes. You need 71-72 booster / m/c / PORP VALVE setup
Old 10-18-2017, 09:33 PM   #35
Drummerboy
Drummerboy's Avatar
So if I just wanted to keep my drums on, I can run a stock booster for '68? Would I need to change the pedal?
Old 10-19-2017, 03:03 AM   #36
BCOWANWHEELS
no
