10-13-2017, 06:56 PM | #1 |
Marvel Mystery Oil....users?
Anyone ever used Marvel Mystery Oil in their engine?....to any results good or bad or?
Oil change stuff? or dumped in the fuel? or? Just curious......having heard a lot of positive stuff about this mystery stuff, whatever it is. all good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
10-13-2017, 07:23 PM | #2 |
Re: Marvel Mystery Oil....users?
I freed up a stuck lifter in my 64 impala SS with it.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
10-13-2017, 08:29 PM | #3 |
Proprietor of Dale's Corner
I used in a motor that had set for years and the rings were stuck. It smoke terribly even after running a total of six hours and a few sets kf spark plugs. I put in and ran it about an hour and it quit smoking and doesn't smoke still.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
10-13-2017, 08:50 PM | #4 |
I use it in a motor that has sat for awhile (like my LS1) pour some in the cylinders and move the motor side to side on the stand.....rotate the crank by hand a few times occasionally.......keeps everything lubed and loose...ready to "wire up and fire up"
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
10-13-2017, 08:59 PM | #5 |
This is a new brand for me ...
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
10-13-2017, 09:34 PM | #6 |
I pour a pint in the crank case occasionally.
I don't have any miracle stories.
10-13-2017, 09:47 PM | #7 |
I used a quart in a 79 350 Chevy that had a tapping sound when it ran. The sound quieted down to nothing after a few seconds and never returned. Just be sure you removed a quart of oil if you add a quart of mystery oil
10-13-2017, 09:56 PM | #8 |
It's also a good lubricant for air tools. I like it for engines that have been sitting too.
10-13-2017, 10:14 PM | #9 |
Quieted a noisy lifter in my dad's truck while we were on the road a few years back. Hasn't made a noise since.
1972 Chevy K20 2000 Chevy Blazer ZR2 2006 Chevy Monte Carlo (wife's) |
10-13-2017, 10:52 PM | #10 |
motor exploder
MMO is legit! I pour it in a day or two before I change my oil, it really cleans an engine out. I also use it about every other tank of gas, both in my '05 GMC and my '65 Bel Air. I use Marvel Air Tool Oil also. Naptha is the active ingredient if I'm not mistaken.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
10-14-2017, 01:08 AM | #11 |
I use Seafoam for my newer cars, MMO for the old stuff. My 70 c10 have been sitting for 15 years; I squirted some MMO in the cylinders and poured it over the valvetrain. Fired right up without issue.
10-14-2017, 08:44 AM | #12 |
I usually pour a little down the carb on my vehicles at a fast idle then shut them off when I pack them away for the winter. It lubes all the cylinder's and they always fire right up in the spring.
10-14-2017, 10:42 AM | #13 |
10-14-2017, 10:44 AM | #14 |
Interesting stuff guys.....so it seems everyone puts it in their crankcase, or maybe down their carb for storage.
Anyone pour it into their gas tank and use it that way? Is it a good product for newer engines? I've got a couple of quarts of this stuff last year and I'm keen to try it out. Coley
10-14-2017, 01:43 PM | #15 |
Quited my lifter noise in my chevelle.
10-14-2017, 02:08 PM | #16 | |
If anyone has some clarification I would love to hear it. |
10-15-2017, 08:02 PM | #17 |
its NOT approved by the FAA for aircraft engines.
they did an analysis of it and determined that it was recycles waste oil, vegetable oil and transmission fluid. |
10-15-2017, 09:11 PM | #18 | |
Seriously though, I remember hearing about MMO in the 70's but never really tried it. Bill
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
10-16-2017, 08:28 AM | #19 |
It's nothing new and a great product no matter what FAA says...unless we're talking airplanes. Only know great stories and no bad ones. My friend had a mower seize up tight, poured MMO in crankcase, and plug hole, let it sit, freed it up and used mower for years. I wouldn't do that with an airplane, though. I believe it has castor oil in it and I know that is good for cutting the crap and freeing things up in an engine from personal experience with using Castrol. Also know an old hot rod brakes expert (all drum) who uses ATF and acetone mix on ceases brake lines with great success. Never buys PB, Creep, Kroil, Liquid Wrench, etc. All that stuff is mystery ingredients and he says the two he uses are all you need.
10-16-2017, 09:18 AM | #20 |
All about them K’s
I use it every day on both engines i build and engines I work on out in the oil and gas fields.
Over time our engines develop a lot of carbon from the well gas they run on. Marvel does wonders in cutting the carbon and keepin everything running smooth. I’ve seen some of our old Waukeshas’ seize up tight with carbon, squirt a little marvel in the plug holes and let it set for a couple hours. Come back work it back and forth a bit and let it eat. I’ve used it in the fuel system before too in my old trucks and does help keep them running smooth.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
10-16-2017, 09:58 AM | #21 |
it was originally designed for the engines and fuels used in the engines of Yesteryear . the active ingredient is standard solvent (white spirits) which aide in the softening of lead and carbon deposits , our old engines are no where near as efficient as those of today . we changed the oil every couple thousand miles (or sooner) along with the plugs and filters . Its basically a high detergent used to clean the inside of your engine of contaminants from the high lead based fuels and ash/carbon content in the oils along with the varnishes in the fuel system and those produced in your transmission . Yes it works if your dillegent in changing your filters and fluids based on the OLD recommendations from GM .Remember these old stock engines where considered tired at 50,000 miles and worn out at anything near 100,000 miles . First the valve guides would go and then the trans followed by the rings and bottom end . the old fix was to use straight 30 weight oil NON DETERGENT oil and just let the engine clog up until it died .Then rebuild or replace it . It's one of the reasons that so many guys find their trucks with odometer readings in the 60-75,000 mile ranges with a running smoking engine . We're dealing with 50 year old technology here .
According to the company's 2015 safety data sheet Marvel Mystery Oil is composed of: Petroleum Distillates (Hydrotreated Heavy Naphthenic) also known as mineral oil, 60-100% Petroleum Distillates (Stoddard Solvent) also known as white spirit, 10-30% http://www.marvelmysteryoil.com/index.php/site/faq/ https://en.wikipedia.org/wiki/Marvel...il#Composition http://www.chemicalland21.com/indust...OROBENZENE.htm Change your filters and fluids based on the recomended schedule from GM for your model truck ,Back then it was 3,000 miles or sooner based on work load . Yes it works on air cooled piston general aviation engines to remove lead deposits ( from running 100 LL-low lead fuel) on the valves that would hinder sealing and thus lower compression levels , It's a fix used by general aviation to pull the upper plugs on a low compression engine ( 2 plugs per cylinder 1 upper and 1 lower ) and add the marvel mystery oil to set over-nite , the next day they would remove the lower plug and drain the mystery oil , then using a dead blow hammer they would SMACK the end of the valve stem forcing it open to allow the valve springs to slam the valve closed again thus breaking any lead deposits off the valve seat which resulted in a better sealing cylinder and raising the compression back to allowable continued use parameters for general aviation standards rather than pulling the cylinders and sending them out to be rebuilt . The FAA doesn't look fondly on the procedure being as it's a cheap repair rather than an approved fix by rebuilding .a single can of marvel mystery oil found in a commercial aviation maintenance hanger could cost them their flight repair license and fines . Last edited by Grumpy old man; 10-16-2017 at 10:20 AM. |
10-16-2017, 11:55 AM | #22 |
If it's stuck, give MMO a try. If MMO doesn't unstick it you're going to end up tearing it down anyway.
I've used it for years on all types of engines.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
10-16-2017, 04:02 PM | #23 |
I added a 1/2 quart of it yesterday to top up the crankcase.
....we'll see if there is any apparent difference. Right now the truck is running great, so it doesn't really have a lot of 'work' to do....but, by the sounds of it.... it can't hurt. Coley
10-16-2017, 05:17 PM | #24 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
I've been using it for years in everything from the 49' 8N Ford tractor (only Ford allowed on the property) to my newest vehicle on the property, a 91 Jeep Cherokee with over 600K on the clock. I just freed up a 68 350 that had been sitting for ten years with my MMO elixir, one part each acetone, trans fluid, and Marvels Mystery Oil...It's great on pancakes too!
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
10-16-2017, 08:36 PM | #25 |
I just came in the house from putting a quart into a '71 GMC 1500 with a 402 in it and a valvetrain clatter. Cam going flat? Out of adjustment? Stuck lifter? I figured those were the choices. Ran it for about 20 minutes in the drive way doing a good old fashioned "rev-tune" and sure enough, it quietened down a BUNCH. Will do this several more times then an oil and filter change and will run it!
