Old 10-17-2017, 10:39 AM   #26
JohnJ@RideTech
JohnJ@RideTech's Avatar
Re: Clifford the Big Red Truck~~The Build
How's it coming Bubba?
John J.
Sales/Tech
Direct Line: 812-481-4737
Office: 812-482-2932
JJohnson@ridetech.com
Instagram: @ridetech_john
JohnJ@RideTech is offline   Reply With Quote
Old 10-18-2017, 09:52 AM   #27
1957 Chief
Retired USAF
Apologize John. Got busy working on the frame and haven't really been documenting it here on the thread. I did however take lots of pics. Finally finished the 12 bolt so I will be able to finish the rear 4-link install today.
So ill prolly do an update with pics later today/tonight for those folks watchin.
I did get the 6.2 and the tr6060 in the frame and hung the exhaust up tho :-)
Bubba
1957 Chief is offline   Reply With Quote
Old 10-19-2017, 10:10 AM   #28
1957 Chief
Retired USAF
Teaser pics. Ill do a writeup later today.
Old 10-19-2017, 11:20 AM   #29
82streetshow
coming along nicely
82streetshow is offline   Reply With Quote
Old 10-19-2017, 11:28 AM   #30
JohnJ@RideTech
DAMN!!! Looking good! I've got some stuff headed your way. Check your email.
John J.
Sales/Tech
Old 10-20-2017, 09:40 AM   #31
1957 Chief
Retired USAF
Originally Posted by 82streetshow View Post
coming along nicely
Thanks gentlemen. Im trying here. :-)
Ok so lots of stuff happening this last week and a half. Ill try and go chronologically.
After the front end suspension was semi complete, I went ahead and installed the motor/trans. First off, had to switch to a CTS-V pan. I really happy about the fitment of the pan AND the oil capacity. Since it holds 6 quarts, I chose not to run an external oil cooler.
Previous motor had the truck pan, it hung below the front crossmember. You can't even see this one from the front. Totally satisfied with it.
Old 10-20-2017, 09:45 AM   #32
1957 Chief
Retired USAF
New up was getting the motor home and installing the clutch and trans.
Was able to score a Mantic twin disc setup from a good buddy of mine.
Old 10-20-2017, 09:45 AM   #33
LT7A
Very clean work.
Old 10-20-2017, 09:50 AM   #34
1957 Chief
Retired USAF
Next up was sitting the motor and trans in the frame. I used the same motor mounts as I did on the first truck, stock altered ones. While I am dropping a lot of money in this, might as well use what I can. When we put the motor in it, I told my son that this is the first time I have ever put in a motor from the side.
Old 10-20-2017, 09:57 AM   #35
1957 Chief
Retired USAF
So when using truck accessories with a motor with VVT and a low rise intake, you have to move the idler pulley as well as change the water pump. You also have to cut off some material on the upper bracket for the outlet hose on the pump. Quick call to summit and ordered a ICB bracket and then chopped off the stuff in the way, and installed the L99 pump. Problem solved.
Old 10-20-2017, 10:11 AM   #36
1957 Chief
Retired USAF
Next up was temporary installing the exhaust and checking the fitment of the rear trans mount/crossmember. Gotta use an adapter back there too for the mount. The TR6060 mount is about 4 inches further back than the 4L60. I was concerned about the crossmember getting into the "catalytic converter" curve, as well as hitting the exhaust. So I am 1 for 2. It doesn't go near the curve, but it hits the top part of my exhaust. Not by much tho, so most likely a tap with a hammer will be in order.
Old 10-20-2017, 10:21 AM   #37
1957 Chief
Retired USAF
So the old truck had a 10 bolt with 3:73's with an eaton diff. When I bought this new frame to start the build, it ha a 12 bolt. I decided to run that since we were switching to a manual. I know some folks swear by the strength of a 10 bolt, but I decided to go with the 12. I already had Wilwoods on the 10 bolt so i just switched them over.
The 12 bolt has 3.42 gears, eaton diff and all new bearings and seals.
I also switched out the wheel studs to longer ones. When I put the disc brakes on the rear, I didn't like the length of the studs. I never got around to changing them on the 10 bolt, but did on the 12. The original studs are a .535 knurl, these are a .547 knurl (dorman part number 610-298.) You will need a 17/32 drill bit to open the axles up. They have a small shoulder on them, so make sure your wheels will cooperate. I also had to drill the brake hats out to fit over them.
I also cut off the shock mounts on the rearend because I'm using the ride tech rear 4 link suspension and I won't need em.
Old 10-20-2017, 10:31 AM   #38
1957 Chief
Retired USAF
Next up was putting the rearend back under the frame. One of the beauties of the ride tech system, is its simplicity. I installed the upper and lower brackets on the axle and snugged em up, then rolled the rearend up under the frame and hooked the 4-link bars on. Then installed the pan hard bar. Was like a bowl of biscuits and gravy...easy. Then jacked it up and installed the coilers.
So easy a caveman can do it.
Old 10-20-2017, 10:39 AM   #39
1957 Chief
Retired USAF
So as it sits now,
I have to snug up the exhaust (after I clearance it)
Drill a couple new holes in the frame for the crossmember
Finish running the brake lines on the frame
Figure out a scatter shield/blanket for the bell housing
Set up the rear fuel tank and plumb the lines/filter to the intake
Plumb the trans cooler lines to the front of the truck
Run battery cables from the rear to a front power distribution block
Get the driveshaft finished
Then ill take a break and start working on the truck side of it for the clutch pedal assembly, take measurements to see how much I will have to raise the trans tunnel.
And I'm sure more stuff.... Also if any of you guys have questions or need measurements, holler at me.
Bubba
Old 10-20-2017, 10:41 AM   #40
1957 Chief
Retired USAF
Oh yea, forgot to mention that I go try new harness from Andy at Swap Specialties. Its sexy
Old 10-20-2017, 10:41 AM   #41
1957 Chief
Retired USAF
Originally Posted by LT7A View Post
Very clean work.
Thanks brother.
Old 10-20-2017, 12:45 PM   #42
daddyjeep
daddyjeep's Avatar
That really is a good looking harness. I like that loom... heat shrink on the ends even.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 10-20-2017, 03:13 PM   #43
82streetshow
put a V pan on mine several years ago for the same reason, the clearance is about perfect
Old 10-20-2017, 07:34 PM   #44
1957 Chief
Retired USAF
Yes, it is a top notch harness. I used the same type on my LS1, and was really satisfied with it. Was a no brainer to do it again for the LS3. And the price didn't break the bank.
You are right. A fella can go nuts reading about pans/mounts/clearance etc. I just read up a lot on them, and saw that two people were at the top of the "search" function with that pan and experience. You were one, so thanks brother.
Bubba
Old 10-21-2017, 08:44 AM   #45
82streetshow
Bubba
Man thats the beauty of these forums, lots of experience out there. It happend by chance for me. Got a crate LS6 to go into a vette here at the shop and it came with V pan on it so had to swap to the vette pan. I kept eyeballing it thinking it would fit my truck better so one day I tried it and the rest is history. Holley makes a good fitting pan but arent very cheap
Old 11-07-2017, 02:31 PM   #46
1957 Chief
Retired USAF
Finally got around to picking up the driveshaft today. I had to get it lengthened about 3.5 inches. So that should be able to get installed this week.
Also placed an order for a Boyd's rear tank yesterday. So will install that and hopefully it won't interfere with the rear crossmember on the ride tech system.
Il have pics and details up as soon as I get that stuff in.
Bubba
Old 11-16-2017, 12:21 PM   #47
DBLSPRT68
DBLSPRT68's Avatar
Just read thru this build... WOW, YOU SIR have some mad skills!!! FANTASTIC INSPIRATIONAL!!!!!!!!!!!!!
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
Old 11-16-2017, 09:46 PM   #48
1957 Chief
Retired USAF
Thanks brother. I wouldn't say mad skills tho, most of that stuff is bolt on...regular feller could handle all that.
Hopefully I should have the gas tank on this weekend. Lots of folks are wondering the fitment on it with the new ride tech rear 4 link.
Thanks again brother
Bubba
Old 11-16-2017, 09:54 PM   #49
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Glad your Son is OK. Your attention to detail is great, going to be sweet. Cant wait for more!
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 11-18-2017, 09:48 PM   #50
1957 Chief
Retired USAF
Thanks brother. Hopefully should see some movement this week. I mounted the rear tank today and ill get some pics up tomorrow.
Bubba
