292 carb heat
I have a small Holley 4bbl on an offy intake. Routed the coolant water to the
intake manifold bottom plate from the left side of the head. The outlet I was going to route into the return heater hose. Just wanted to make sure this would circulate enough antifreeze to provide heat for the bottom of the carb on this old six cylinder. I used 3/8ths copper line and was going to put together something to T into the 5/8ths heater hose on the other end. Any comments? Any other options? I'd like to find out if this is wrong before finding out the hard way. |
#2 | |
The Older Generation
Re: 292 carb heat
Here is an article on the subject with a good illustration included... http://www.langdonsstovebolt.com/tec...take-manifold/ LockDoc
Re: 292 carb heat
I did the same on my early style Clifford that doesn't have the internal passage. I used a thermostat housing that had two threaded bosses. One is for the heater hose, the other had a plug in it. The other copper line from the plate I made to fit under the manifold went around the back of the engine to a heater hose T like you mentioned.
Seems to work on mine, but I'm in a warmer climate.
'67 GMC 2500, 292, 4spd, AC |
Re: 292 carb heat
I ran mine as the by-pass line that the 292's have. Of course, you have to have it set up for the smaller line as opposed to the 1 1/4" by-pass line that the older 292's have.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
#5 | |
Re: 292 carb heat
Got it, thank's for all the help.
Posted via Mobile Device |
#7 | |
Re: 292 carb heat
I also have a 235 6 cyc in my 51 chevy with a set of Fenton headers with original intake. The Fenton's (and William's) headers are pre drilled and threaded for heat. I just ran a small piece of copper tubing from each header into a plate under the carb. I think it's cleaner looking, no chance of water leak, and instant heat as soon as you start it. I'm thinking of drilling & tapping these new manifolds and doing same thing with them. These are just my thoughts. |
#8 | |
Re: 292 carb heat
Your right,the exhaust heat would be much better if you can get enough through the small copper lines. How did you fasten the copper lines to the exhaust manifolds?
#10 | |
Re: 292 carb heat
hope this works |
