View Poll Results: Motor Options
Stick with the LS3 32 71.11%
4bt Cummins 13 28.89%
Voters: 45. You may not vote on this poll
Old 10-24-2017, 10:49 PM   #1
Jmh68C10
Jmh68C10's Avatar
Ls3 vs. 4bt Cummins
I am mid build on my c10 project. Using all porterbuilt suspension and a ls engine swap. (you know the same thing everyone seems to be doing) so I got the idea of changing it up and using a 4bt Cummins for my engine. Biggest issue I see from first glance would probably be the oil pan needed modification to fit with the drop member. Just brain storming....
68 c10- Under construction
Jmh68C10 is offline   Reply With Quote
Old 10-25-2017, 02:54 PM   #2
Dmaxmoe
Re: Ls3 vs. 4bt Cummins
I didn’t vote because I’m not driving yet, but pretty much went through this same thing minus the drop member part. I’ve read of 1 or 2 guys on here that went 4bt and didn’t like it so went duramax, who knows their setup or the health of the engine for them to not have like it though.
Im just getting ready to drop my p-pump 4bt into my 69, hopefully be driving mid nov. I chose 4bt because I don’t want any extra electronics, it’s a summer driver, noise doesn’t bother me, and it will be way different. Semi built 4bt with properly sized compounds, moderately fueled and pump dialed in should be more then enough. I’m sure you could get creative with the oil pan if you go that route.
It’s all in your expectations and wether or not you’re at all familiar with diesels, don’t expect an easy 400 hp out of the little cummins either. Check out 4bt swaps, they aren’t too heavy in the hp chasing over there, but a few have taken them pretty far.
Dmaxmoe is offline   Reply With Quote
Old 10-25-2017, 08:56 PM   #3
BCOWANWHEELS
A 4bt is very noisey, very tall and super heavy not to mention very costly. I have 6 of them so i know.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 10-26-2017, 01:50 PM   #4
cypressbog
Go Pack Go!
I'm not sure how anyone could compare the two. Stick with the LS.
cypressbog is offline   Reply With Quote
Old 10-26-2017, 02:23 PM   #5
JustToxic
JustToxic's Avatar
Unless your building a 4x4 or a rat rod truck, I'd keep the LS.
1967 Chevy C20 to K20 Conversion "Simply Toxic"
http://67-72chevytrucks.com/vboard/s...d.php?t=749409
1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775
JustToxic is offline   Reply With Quote
Old 10-26-2017, 03:25 PM   #6
Tomo
Way out of my price range but maybe something to consider
Cummins' new 2.8 crate engine
https://cumminsengines.com/repower.aspx
Tomo is offline   Reply With Quote
Old 10-26-2017, 04:12 PM   #7
randy500
That’s a cool engine...
randy500 is offline   Reply With Quote
Old 10-26-2017, 04:45 PM   #8
Kw69
Kw69's Avatar
I like both, but the LS will be an easier swap from what I can gather. Regardless keep us in the loop with pics when u do it!
2009 GMC 2500HD 6.0, 6 speed auto, stealth grey, 4x4 Z71, Bilsteins, Black Bear Tuned. Pulls the 10k fifth wheel all so easy.
1969 CST 350 black long bed, 3 on the floor, PS, AC, drum brakes, old school and love it.
Kw69 is offline   Reply With Quote
Old 10-27-2017, 12:44 AM   #9
HO455
HO455's Avatar
The first thing I have to ask is... Is the Porterbuilt front end up the the task of living under the 4BT? Please don't feel I'm bashing the Porterbuilt equipment but it is asking a lot. Those engines are easily 750 pounds without things like radiators or A/C.
RIP Bob Parks.
Old 10-27-2017, 01:19 AM   #10
Dmaxmoe
The 4bt is heavy for sure, listed at around 750lbs wet, but the big blocks that came in these generations of trucks are listed at 650-685 dry, so according to the internet, not all that different. Obviosuly no comparison if we are talking aluminum blocks/heads.
Old 10-27-2017, 05:50 AM   #11
hamjet
hamjet's Avatar
I say go for the cummins, if you're looking for a challenge or just want to be different and can afford it, then go for it. might be a lot of work but when done, what a looker....((( its amazing, I just went to other sites I look at and nothing but cummins advertisements on them just because I typed the word 'cummins')))
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 10-27-2017, 01:44 PM   #12
trac209
4bt would be a cool swap and a step above the general LS style one. May cost a bit more but the longevity of the Diesel engine far outweighs the savings of an LS.
trac209 is offline   Reply With Quote
Old 10-28-2017, 09:53 PM   #13
bill3rail
bill3rail's Avatar
I voted for the Cummins as I want one myself. Different from everything else out there!
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
