Old 10-24-2017, 06:02 PM   #126
Kennuck
Kennuck's Avatar
Re: LSX swappers what ya got?!?!
[QUOTE=BR3W CITY;5896635]
[B]Model: 1970 C10
[B]Motor/transmission: 2002 5.3 4L60E
[B]Fuel tank: Boyds
[B]Motor mounts: Ebay
[B]Tranny mount: CPP
[B]Oil pan: Stock
[B]Radiator: Stock 4 row
[B]Shift linkage: Lokar
[B]Exhaust manifolds: Trailblazer SS
[B]Gears: 3:73
[B]Rear End: GM 12 bolt
[B]Tire size: 275 60 18
[B]Bagged: Static 2.5" 4"
[B]Running: Yes
[B]Build thread: No
[B]Carb or FI: Stock EFI
[B]Go Fast: Blackbear Performance Custom tune
Torque management removed.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 10-26-2017, 11:40 PM   #127
'68 C10
Model: 1972 GMC C10
Motor/transmission: 2001 LM7 5.3/4L60E
Fuel tank: Stock in cab.
Motor mounts: CPP sheet metal perches/CPP mounts & sliders
Tranny mount: CPP tubular w/ poly mount
Oil pan: Stock 5.3 pan
Radiator: 2001 Silverado LS rad w/ LS1 EFans
Shift linkage: Lokar ACA-1800
Exhaust manifolds: Speed Engineering 1 3/4 Mids w/ 3" collectors
Gears: Stock, unsure of gears
Rear End: Stock, 12 bolt
Bagged: No. Soon to be 2" spindles/1" coil springs and lowering leafs & shackles
Running: Not yet
Build thread: Not yet
Carb or FI: FI - External Walbro, Corvette regulator, returnless fuel rail
Go Fast: Not yet
'68 C10 is offline   Reply With Quote
Old 12-07-2017, 03:15 PM   #128
robertsjm711
robertsjm711's Avatar
Model: 1953 3100
Motor: 2002 5.3 Flex
Transmission: Muncie M20
Oil pan: Truck
Motor mounts: Custom
Tranny mount: Custom
Tranny Tunnel: Slight hump
Radiator: Griffin Aluminum Pro Series Radiators 1-25182-X
Shift linkage: Hurst
Exhaust manifolds: 1982-04 Chevrolet S10 Blazer LS1 Sonoma Engine Swap Headers Stainless by Racing Innovation Supply
Gears: 2.29 (will go 3.73)
Tire size: 29"
Carb or EFI: EFI
Bagged: No
Running: Soon. ish.
Go Fast: Right foot
It was said that if you cut off one hydra head, two more grow back.
-Lernaean Hydra
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=743246
robertsjm711 is offline   Reply With Quote
Old 03-27-2018, 09:50 PM   #129
darrellyates
Originally Posted by darrellyates View Post
Ok, I'll give this a go:
Model: 1970 C10 SWB
Motor/Trans: LS3/4L60E
Motor Mount: On custom Frame
Trans Mount: On custom Frame
Oil Pan: "F" Body
Radiator: Moosehead custom aluminum
Shift Linkage: Not yet
Exhaust Manifold: "Shorty" SS headers... E-Bay cheapie...
Gears: 3.70
Rear End: Moser - 4 bar w/panhard rod
Tire Size: ??? Not yet...
Bagged: No. Static Ride Tech coilers
Running: Not yet.
Build Thread: If I could figure it out...
Carb/EFI: EFI, factory port fuel injection.
In Progress....
Finally got it up and going. Hope you enjoy the progress as much as I do!
darrellyates is offline   Reply With Quote
Old 03-27-2018, 10:02 PM   #130
mongocanfly
mongocanfly's Avatar
that's a bee-uti-full truck Darrell
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-24-2018, 12:15 AM   #131
Ghost's68
Ghost's68's Avatar
Model: 1968 C10 SWB
Motor: 5th gen Camaro LS3
Transmission: Jakes performance stage 2 4l80e
Oil pan: Cadilac CTSV
Motor mounts: CPP stands with DD sliders
Tranny mount: Energy suspension (red)
Tranny Tunnel: Low hump
Radiator: Entropy dual pass with electric fans
Fuel tank: Boyd’s EFI with built in Aeromotive Stealth
Shift linkage: Stock for now
Exhaust manifolds: Kooks TBSS long tubes
Gears: 3.70
Rearend: ford 9” with Eaton Trutrac
Tire size: 28” will upgrade to taller tires
Carb or EFI: EFI
Bagged: Static drop ECE 4/6
Running: I wished
Go Fast: Custom speced Pat G cam, AI heads, Mamo 102, ported NW 102. Long tubes when I know what fits my build lol.
Ghost's68 is offline   Reply With Quote
Old 05-12-2018, 10:51 AM   #132
69ls4.8swap
Model: 69 c10 CST
Motor/transmission: 2000 4.8/4l60e
Fuel tank: universal by tanks
Motor mounts: dirty dingus with stock
Tranny mount: stock
Oil pan: 4..8 stock
Radiator: 69 stock
Shift linkage: lokar
Exhaust manifolds: speed engineering
Gears: 3:73
Rear End: 69 12 bolt eaton
Tire size: 275/60-15
Bagged: no
Running: yes but not moving yet
Build thread:
Carb or FI: factory 00 FI
Go Fast:not sure yet
69ls4.8swap is offline   Reply With Quote
Old 05-18-2018, 04:52 PM   #133
dropped_71chevy
Originally Posted by 69ls4.8swap View Post
Model: 69 c10 CST
Tranny mount: stock
Oil pan: 4..8 stock
Radiator: 69 stock
Gears: 3:73
Bagged: no
Build thread:
How'd the Tanks universal work out for you? Any pics? Feel free to pm me.
dropped_71chevy is offline   Reply With Quote
Old 06-27-2018, 07:35 PM   #134
binford
Model: 1971 C20
Motor/transmission: 2006 6.0 4L80E
Fuel tank: Stock
Motor mounts: Ebay 5/16" thick
Tranny mount: Stock 350 mount
Oil pan: Stock truck pan
Radiator: ...
Shift linkage: ...
Exhaust manifolds: LS 6.2 Camero Ceramic coated inside and out.
Gears: 4:10
Rear End: Dana 60
Tire size: 245 75 16
Bagged: Leaf springs
Running: ...
Build thread: ...
Go Fast: Installing the 6.0
Torque management. LT1 swap tune
binford is offline   Reply With Quote
Old 10-10-2018, 01:47 PM   #135
1957 Chief
Retired USAF
Model: 1986 Silverado
Motor/transmission: LS3 6.2/TR6060
Fuel tank: Rear mounted Boyd's tank with internal fuel pump
Motor mounts: Home made
Tranny mount: Hooker double hump cross member
Oil pan: CTS-V
Radiator: 2004 Silverado with 2007 Silverado cooling fans
Shift linkage: MGW Short Throw
Exhaust manifolds: Ebay stainless headers
Gears: 3.42
Rear End: 12 bolt with Eaton Diff
Tire size: Front 18x9 4.5bs-275/35/18 Rear 18x10 5bs 275/35/18
Ridetech front/rear coilovers susp/Wilwood front/rear brakes
Running: Like a Beast
Carb or FI: Ported LS3 intake
Go Fast: Stage 3 GPI heads and cam
1957 Chief is offline   Reply With Quote
Old 10-10-2018, 02:30 PM   #136
nlped
nlped's Avatar
^^^ That’s dead SeXy!!! It’s what I’d like my 77 to end up like...
And, on another note... my mom’s entire family is from Beebe/Garner AR. Small world
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 10-11-2018, 06:44 AM   #137
OKGMC4
OKGMC4's Avatar
Originally Posted by OKGMC4 View Post
Model: 1956 GMC
Motor/transmission: 2001 5.3 / 4L60E
Fuel tank: aluminum aftermarket with silverado fuel pump
Motor mounts: custom stands to early sbc pedestal style
Tranny mount: modified 2nd gen F body cross member
Oil pan: F body LS1
Radiator: champion
Shift linkage: Lokar cable, column shift
Exhaust manifolds: 1997 Corvette
Gears: 3.07
Rear End: dana 36, 1996 corvette
Tire size: 245/45r17 front, 275/40r18 rear
Bagged: no
Running: yes
Build thread: in my sig
Carb or FI: stock efi
UPDATED:
Model: 1956 GMC
Motor/transmission: 2005 6.0 / 4L60E w/Yank SS3200
Engine mods: bored .020, flat top pistons, TS&P 224R cam
Oil pan: F body LS1
Radiator: champion
Exhaust manifolds: Dougs D314 headers for 73-87 LS swap
Gears: 3.07
Rear End: dana 44, 1990 corvette
Tire size: 275/40r18 front, 275/40r18 rear
Bagged: no
Running: yes
Carb or FI: stock efi with flex fuel injectors
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 10-16-2018, 02:04 PM   #138
Beau2a
Beau2a's Avatar
Model: 1971 GMC Custom
Motor/transmission: 2006 Tahoe L59 5.3/4l60e
Fuel tank: 1987 Blazer 25 gallon
Motor mounts: DD sliders
Radiator: American Eagle W/ Electric fans
Exhaust manifolds: 2012 Camaro
Gears: 3:07
Rear End: 12 bolt
Tire size: 235 75 15
Running: yes
Build thread: no
Go Fast: Not yet
Beau2a is offline   Reply With Quote
Old 10-18-2018, 01:10 PM   #139
'68 C10
Originally Posted by '68 C10 View Post
Model: 1972 GMC C10
Running: Not yet
Go Fast: Not yet
Update:
Model: 1972 GMC C10
Tranny mount: Dirty Dingo
Radiator: Champion Radiator with Efans/Shroud
Exhaust manifolds: Speed Engineering 1 7/8 LTs
Bagged: No. 4” drop leafs/3” drop springs. Not low enough.
Running: Yes
Build thread: Yes - http://67-72chevytrucks.com/vboard/showthread.php?p=8356099#post8356099
Go Fast: TSP Stage 2 Truck Cam low lift, PRC 5.3 Stg 2.5 Heads
Old 11-09-2018, 10:57 PM   #140
the ideaman
the ideaman's Avatar
Model: 1967 C10 SBW,SWB fleetside
Motor/transmission: 480 horse LS3 with Tremec tko500
Fuel tank: Boyds welding tank
Motor mounts: SBC+ ebay brackets with CPP stands
Oil pan: Chevy performance Hot Rod Pan
Radiator: Entropy with dual fans
Shift linkage: mid shift with Lokar 16" curved shifter handle
Exhaust manifolds: Doug Thorley 1 5/8th"s tri y headers
Gears: 3.73
Rear End: Truck 12 bolt, 5lug Henry's Axles
Tire size: Rear 265/70/15 on Halibrand style repros
Bagged: no
Running: not yet...
Build thread:
Carb or FI: FI with GM controller
the ideaman is offline   Reply With Quote
Old 12-28-2018, 08:29 AM   #141
trobert3
trobert3 is offline   Reply With Quote
Old 01-12-2019, 02:47 PM   #142
jrusher
Model: 1965 c10
Motor/transmission: 2008 Ly6 6 litre /4l80 2500 stall, TSP cam etc
Fuel tank: My own custom aluminum under bed
Motor mounts: dirty dingo sliders with stock
Tranny mount: CPP
Oil pan: Gm performance muscle car pan
Radiator: 65 stock
Exhaust manifolds: speed engineering 1 7/8 long tube
Gears: 3:07 for now going 3:73 and posi soon
Rear End: 65 12 bolt
Tire size: 275/50/20 235/50/18
Bagged: Rear bagged front drop spindle
Running: yes
Build thread:
Carb or FI: factory
Go Fast:
jrusher is offline   Reply With Quote
Old 01-22-2019, 05:45 PM   #143
dcatlin
dcatlin's Avatar
the truck in my profile pic was built by me in 2015, 2003 6.0 lq9 drive by cable, tied to a 700r4, ss gas tank between the frame rails, duals all the way to the bumper, daily driver. youtube page= Dennis Catlin
She is up and running- youtube
dcatlin is offline   Reply With Quote
Old 01-23-2019, 02:43 PM   #144
rowdy11
Model: 1970 K10
Motor: 2011 L96 w/VVT
Transmission: 2011 6L90E
Trans Case: NP 205 with Atlas Kit
Oil pan: Stock
Motor mounts: Dirty Dingo
Tranny mount: TBD/Custom Fab
Tranny Tunnel: High Hump
Radiator: TBD
Fuel tank: Boyds is the plan...
Shift linkage: TBD
Exhaust manifolds: Stock
Gears: 4.10
Tire size: 35"
Carb or EFI: EFI
Bagged: can you call a 6" lift bagged?
Running: not yet...deep in progress...
Go Fast:
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=773647
1970 K10 Shortbed LS L96 6L90
Follow the entire mess below!
Lola: My Moon Shot
rowdy11 is offline   Reply With Quote
Old 01-26-2019, 02:33 AM   #145
mongocanfly
Model: 1981 c30
Motor/transmission: LQ9/NV4500
Fuel tank: stock
Motor mounts: stock with ebay adapters
Tranny mount: stock
Oil pan: stock
Radiator: stock
Shift linkage: stock
Exhaust manifolds: stainless headers
Gears: .10
Rear End: 14bolt
Tire size: 30"
Bagged: no
Running: yes
Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=753598
Carb or FI: FI
Go Fast: it will
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 12-07-2020, 04:22 PM   #146
bigmoe
bigmoe's Avatar
Model: 1965 GMC short Fleetside
Motor/transmission: 2008 Gen IV LMG 5.3/4L60E
Fuel tank: Tanks Inc USPT-GH
Motor mounts: Blackheart Racing plates (3rd position forward)
POL tubular mounts
Tranny mount: aftermarket modified for exhaust
Radiator: RND Fabrication (forum sponsor discount)
Shift linkage: Art Carr Winters 177-1
Exhaust manifolds: Speed Engineering shorties
Gears: Stock, 3.42
Rear End: Stock, 12 bolt 79C10
Lowered: 2 1/2" drop spindles, Jeep rear coils
Running: tip top
Build thread: yes
Carb or FI: factory FI - internal Walbro, Corvette regulator, returnless fuel rail
Wheels: 17 x 8, 4"bs, US Mags Ramblers 235-60-17 and 255-60-17
bigmoe is offline   Reply With Quote
Old 12-15-2020, 09:39 PM   #147
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Model: 1970 K10 swb fleetside
Motor: 2000 5.3L LM7 (Yukon)
Transmission: 4L60E Level II rebuid from Bowtie Overdrives
Oil pan: Tilden custom fabricated
Motor mounts: Pacific Fabrication / Tilden Motorsports 4WD crossmember with motor mounts
Tranny mount: Stock with Advanced Adapters 4L60E to NP205
Tranny Tunnel: High hump
Radiator: Northern Radiator 209603B with dual Spal electric fans
Fuel tank: Ricks stainless tank with Walbro in tank pump
Shift linkage: Column/Lokar
Exhaust manifolds: Speed Engineering headers model 25-1021
Gears: 3.73
Tire size: 33"x12.5"x15"
Carb or EFI: EFI
Bagged: No, 2-1/2" lift kit by Skyjacker
Running: Yes
Go Fast: It Goes
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=782232
Name:  K10 with Rally wheels - 3.jpg
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 01-09-2021, 06:10 PM   #148
Justin71105
Still very much a project
Model: 1964 C10 Fleetside SWB
Motor: 2003 5.3 (Tahoe)
Transmission: 2003 4L60E with Corvette servo (Tahoe)
Oil pan: 2003 Tahoe
Motor mounts: ICT
Radiator: CC284 Champion LS swap radiator
Fuel tank: No Limit 19 Gallon aluminum tank
Shift linkage: None yet
Exhaust manifolds: Speed Engineering longtubes
Gears: 3.73
Tire size: 28"
Carb or EFI: EFI
Running: not yet...
Build page:
https://67-72chevytrucks.com/vboard/...d.php?t=812156
1964 C10 Rusto-mod
5.3L - L59 Flex Fuel
BTR Truck Norris
Justin71105 is offline   Reply With Quote
Old 02-11-2021, 12:54 PM   #149
First c10
First c10's Avatar
Model: 1970 Custom CST LWB K10
Motor/transmission: 2008 ly2-4/L60E
Fuel tank: 90 Blazer tank in rear pump in tank with filler in taillight
Tranny mount: 90 burb
Oil pan: Stock 2008
Radiator: Champion Aluminum with 2 electric fans
Exhaust: All SS exhaust with Shorty headers and cutout/Magnaflow
Gears: 3.73 Posi
Rear End: 12 Bolt Front Dana 44
Tire size: 33/12.50R15 on 10 Alcoa's
Lift: Custom 5" Lift
Running: Yes, build is almost complete.
Build thread: See signature
Go Fast: TorqueStorm Supercharger
Picture is from sometime back but you get the idea!
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 12-10-2021, 09:27 PM   #150
oldman3
oldman3's Avatar
Model: 1950 Chevy Roadster pickup
Motor/transmission: 5.3 LM7 - 4L60E
Fuel tank: Custom
Motor mounts: ICT Billet and Prothane
Oil pan: TSP
Radiator: Champion
Shift linkage: Lokar floor shifter
Exhaust manifolds: Block Hugger SS
Gears: 3??
Rear End: Nova
Tire size: 235/55/17 27"tall
Bagged: No
Running: Yes
Build thread: See signature bottom of page (start on page 76)
Carb or FI: EFI Deepmotor fab. intake
Go Fast: crusier
oldman3 is offline   Reply With Quote
