Old 10-29-2017, 10:51 AM   #1
gmc 2500 4x4
clutch rod lever bushing?
has anyone ever used a bushing where the clutch rod connects under the dash? before i hunt for the right bushing i thought to ask here. my lever is egg shaped a bit. i have a nice un-worn rod and would like to get a brass bushing to keep it from wear. any info would help
gmc 2500 4x4 is offline   Reply With Quote
Old 10-29-2017, 11:18 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: clutch rod lever bushing?
This should work .
https://www.classicparts.com/1960-72...info/90%2D769/
You can check Ace hardware to see if they have a bronze bushing you could make work by drilling your mount larger and using a bushing that fits the rod .
Old 10-29-2017, 11:21 AM   #3
gmc 2500 4x4
i just found brass/bronze bushings at https://www.mcmaster.com. this place is great!
Old 10-30-2017, 05:53 AM   #4
gmc 2500 4x4
https://www.mcmaster.com/#2938T6
Old 10-30-2017, 04:43 PM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
GMC1500 4x4, I have had a machinist build up a bushing-reinforced clutch lever. I don't remember if I used it on either truck, or if its still kicking around. But it was a thing of beauty.
Grumpy, those plastic spirals go inside the lateral pivot bar inside the cab. Both the brake and clutch pedals swing on it. Re-installing them cures that ''swingset squeek'' you get on a 40+ y.o. truck. I can't figure out how to get at it however.
Old 10-30-2017, 07:34 PM   #6
Grumpy old man
I can't remember everything , I've got a swingset squeak myself and WAAAYYY past 40 yo .... But I remembered the bronze bushing trick .
Old 10-31-2017, 10:45 AM   #7
gmc 2500 4x4
all fixed, drilled the lever out to 1/2'' and the bushings i got from https://www.mcmaster.com/ did the trick. reference : #2938T6 High-Load Oil-Embedded Flanged Sleeve Bearing for 3/8" Shaft Diameter, SAE 863 Bronze, 1/2" OD, 1/4" Length
Old 12-15-2018, 10:16 AM   #8
gmc 2500 4x4
i have 4 left if anyone needs one
Old 02-28-2020, 03:50 PM   #9
gmc 2500 4x4
ttt
