10-31-2017, 03:33 PM | #1 |
BBC Headers 74 C10
Im new to this whole online forum chatting so please bare with me.
I have a 74 C10 short box 2WD that im putting a 498 stroker block with a 8-71 supercharger in it. I cant find a MFG that has a full length header with 2 1/8 or 2 1/4 primary tube for the truck.I really dont want to do a custom order header. I was reading on other guys using camaro or nova headers on the C10 but their application was with a SBC and their pictures showed a tight fit. Can anyone tell me what years for the camaro and nova headers will work on the 74 C10 and if you have tried it. Thank you |
10-31-2017, 04:14 PM | #2 |
Re: BBC Headers 74 C10
I have 1 3/4" long tube Chevelle/A-body BBC headers on my 89 CC dually. They fit w/o issue. My frame rails are taller so the collector is above the lower lip on the frame rail. on a 1/2 ton rail they would likely hang slightly below the rail.
I also used 1 3/4" 'mid-length' 68-72 Chevelle BBC headers on my 67. I recall slightly trimming the pass side rail for clearance (not necessary but I wanted the same clearance on both sides).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-31-2017 at 04:19 PM. |
10-31-2017, 06:01 PM | #3 |
Thanks for your input.
