Old 10-31-2017, 04:23 PM   #1
JohnJ@RideTech
JohnJ@RideTech's Avatar
NEW Air Management System from Ridetech
Name:  RidePro HP(2).jpg
RidePRO-X — NEW Digital Air Suspension Control System
Sophisticated pressure and height algorithms tune air spring rates for proper handling and world-class ride quality. A sleek and stealthy 3-position Control Module plugs into your car or truck’s 12V power port (cigarette lighter) and talks to the ECM via RF. Choose
pressure-only (RidePRO-X) or pressure and height (RidePRO-HP) for the ultimate electronic air management system.
FEATURES:
- Stealthy 3-position Control Module communicates via RF.
- “Ride Height On Start” automatic lift and level feature.
- Pressure-based crossload compensation — critical for dynamic driving scenarios such as cornering and panic stops.
- Display and setup via smartphone “App”, laptop or optional dedicated bluetooth Display/Tuner.
- Weatherproof ECM and heavy duty mil-spec connectors.
- All new LevelPRO height measuring sensors.
- Automatic weight compensation.
- RidePRO-X (pressure-based) system is upgradable to RidePRO-HP (pressure and height) system.
- Bluetooth connectivity and smartphone app are included.
- $1300 plus shipping and handling.
RidePro-HP ride height sensors upgrade your existing RidePro-X pressure-based system. The ultimate air suspension management system measures BOTH pressure and ride height. With the addition of RidePro-Hp ride height and spring balance (loads) are established by comparing the position of the ride height sensor to the air pressure within each air spring. Your car is leveled with no crossloading. This is especially important for dynamic driving scenarios where quick transitions occur. Examples include high performance driving, sudden directional changes and panic stops. Pressure-only systems are good at handling these load changes, but combined pressure and height systems work best. The complete RidePro-Hp kit is easy to install. The complete RidePro-Hp kit includes: 4 Height Sensors 4 Height sensor linkage kits (with steel linkage rods and rubber rod ends), Group harness, 1/4" sensor bolts w/ Nyloc nuts & flat washers, mounting tabs, Heat shrink tubes and Installation Guide. NOTE: RidePro-Hp sensors can only be used in conjunction with RidePro-X Digital Control System.
- $500 plus shipping and handling.
Check out the article on the NEW RidePro X system on Street Rod Life through the link below.
http://www.streetrodlife.com/tech/air-performance-tips/
John J.
Sales/Tech
Direct Line: 812-481-4737
Office: 812-482-2932
JJohnson@ridetech.com
Instagram: @ridetech_john
JohnJ@RideTech is offline   Reply With Quote
