Old 11-01-2017, 10:57 AM   #26
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Did HEI conversion - cant get truck to start - no spark at plug...
Originally Posted by rotten67 View Post
Have you checked to make sure the distributor rotor is spinning when you crank the engine? Chek the power to the coil key on engine off with a test light should have power on both the positive and negative until you crank it then the negative side shoud flash. Post so. Pictures maybe we can see something thats not right.
...and.... did she fire???
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-01-2017, 02:07 PM   #27
cleszkie
cleszkie's Avatar
Did you replace the ignition module after you wired in a direct 12V from battery? If you fried the module with low voltage, it will not suddenly work again with a clean 12V supply.
cleszkie is offline   Reply With Quote
Old 11-04-2017, 02:21 PM   #28
RichardJ
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 11-04-2017, 03:55 PM   #29
BugzC10
BugzC10's Avatar
Subscribed....the suspense is killink me.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 11-04-2017, 04:10 PM   #30
El Dorado Jim
sub'd, wish I had some advice to give you but seems like you have tried everything I can think of already.....electrical issues can drive you crazy, but don't give up, you will figure it out...
El Dorado Jim is offline   Reply With Quote
Old 11-05-2017, 08:35 AM   #31
panhead59
Don't lose faith. I know it's very frustrating when you can't find the problem. You will though!! You are doing the right things and are asking the right questions. You'll find it and then you'll be an expert!!!! When your biggest hammer looks like the answer ,just walk away and start over another day!!!!
panhead59 is offline   Reply With Quote
Old 11-14-2017, 02:59 PM   #32
57rookie
Sorry for the late reply. I decided to let it sit for a week as it was driving me nuts. I installed some really good ground straps to frame and body and WHAMO!!! She Starts!!! Runs absolutely beautiful now. Many thanks for all the advise. I am definitely now an expert at finding and setting TDC and installing distributors. Would have never thought that block grounding would be an issue but it goes to show you how important good grounding is.
57rookie is offline   Reply With Quote
