Wiper Pump
Have anyone had to change the wiper pump on there C-10? after a little research to my understanding it appears that the standard wiper pump is not to dependable. Can anyone share some light on this subject I am in the process of changing my cab and need to install a wiper pump is there a different pump that is compatible to the c10 set up? any help would be great
Re: Wiper Pump
Make sure it doesn't just need to be primed. Use a plastic bottle with a nozzle that fits into the end of the washer hose, and squeeze water into the hose as you activate the pump. If that doesn't work, look on the threads for using a pump from a 90s car or truck.
Replacing th wiper pump in these trucks is a tedious task and the results may be disappointing for you. |
![]() Join Date: Feb 2016
Re: Wiper Pump
I swapped mine out for a new aftermarket pump when I discovered that parts for my 67 style pump are not available. I made a bracket and bolted it to where the old one mounted. It could use a check valve to get the water pumping faster but it works. There are some photos and a write up in my WBM thread link below. Page 7 post 163.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
![]() Join Date: Nov 2006
Re: Wiper Pump
Stock swp remaned will last your lifetime. Run 75 anti / 25 water mix and dont over tighten your belts
I BELIEVE IN JOHN 3:16 |
#5 | |
Re: Wiper Pump
putting my truck back together it want be as long as it has been Hank |
Re: Wiper Pump
My dad bought my truck new off the lot and according to him, the washer pump NEVER worked, not even once.
He would just pull over and wipe off the glass. I have made a bracket to mount a new pump to the washer bottle bracket and hopefully next summer, I will wire that up and run new hoses. |
Re: Wiper Pump
Sorry, thought said water pump. My bad
