Old 11-06-2017, 05:56 PM   #1
Ole Beater
Electric fuel pump not pumping, Carter P4600HP
Well, I finally got my truck running again but had issues with it dying while driving around. I had put a carter electric pump on it and after a few miles the fuel pressure would drop. I changed the filter and found rust in it so figured there was some rust in the lines or tank. But then had the pump not pump even after the filter change. Also I had a russel pre filter with a 40 micron screen that had some debris but was not totally blocked. So I took the pump apart and found that there is a screen in the fuel pump and was plugging up. Cleaned it up and pump worked fine but the tank is shot so I ordered a new tank.
Ole Beater is offline   Reply With Quote
Old 11-06-2017, 07:49 PM   #2
Aberdare
Aberdare's Avatar
Re: Electric fuel pump not pumping, Carter P4600HP
Filters are indeed the life-saver when you have an old fuel tank... you never know how much garbage is going to be sucked up with a 40-50 yr old tank. The Filters will save your pump from an early demise.
Just my $0.02 worth.
Abe
**RED SEAL CERTIFIED JOURNEYMAN SINCE 1993**
My 1966 GMC Value Van Project
1951 GMC 9430 1-Ton
I'm just going to put an OUT-OF-ORDER sign on my forehead... and call it a day.
Aberdare is offline   Reply With Quote
