11-08-2017, 06:32 PM | #1 |
Proportioning valve question
I,am doing a power drum brake conversion on my 70 c10 and was wodering if the porportioning valve is the same for manuel brakes as power brakes. All help is appreciated
thanks bob
I BELIEVE IN JOHN 3:16 |
11-08-2017, 07:20 PM | #2 |
Re: Proportioning valve question
Yes
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
11-08-2017, 08:33 PM | #3 |
Who Changed This?
Note that power brakes systems have different wheel cylinders and master cylinders (the bores are different sizes). Are you changing those over at the same time?
11-08-2017, 09:14 PM | #4 |
Yes, doing 100 per cent brake job. ALL THAT IS OFFERED FOR WHEEL CYLINDERS IS STD AND FOR THE H/D BIG SHOE BRAKES
I BELIEVE IN JOHN 3:16 Last edited by BCOWANWHEELS; 11-08-2017 at 09:21 PM. |
11-09-2017, 08:13 AM | #5 |
Old member
My understanding of the proportioning valve is it's only used for disc brakes and drums together not for both drums.
Google: A proportioning valve is a valve that relies on the statics to supply a reduced pressure to an output line. A simple example is where spring load applies a reducing force so that the output pressure is reduced. Proportioning valves are frequently used in cars to reduce the brake fluid pressure to the rear brakes.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
11-09-2017, 09:13 AM | #6 |
67-72 parts collector,…
Drum brake trucks have a distribution block.
The 71-87 disc brake trucks have a proportion valve. Just add the brake booster to your current M/C. Done.
11-09-2017, 11:49 AM | #7 |
thanks fellas
11-09-2017, 11:59 AM | #8 |
I'm following this one, let us know how and what you end up doing, I plan on doing the same, Joe..
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
11-09-2017, 01:08 PM | #9 |
Yes - The thing already on your truck that is installed between the master cylinder and the wheels, that the brake lines go into and out of, can be reused for your power brake conversion.
11-09-2017, 06:08 PM | #10 |
I,am just going to reinstall it like it was except with a booster
11-09-2017, 07:10 PM | #11 |
That's what we did on our 68 it works find. A lot improvement over no booster. Powered the drums brakes. We left the original valve in place. Brakes work a lot better.
11-09-2017, 08:22 PM | #12 | |
Old member
That's what I did on the ramp truck.
11-09-2017, 08:41 PM | #13 |
Not to hijack the thread but are those booster brackets hard to come by?
11-09-2017, 08:44 PM | #14 |
Usually an easy pick from one of the many truck being parted on the parts board. Sometimes sellers prefer to sell with the booster which adds weight and cost, but understandable if all is in good condition. Captainfab also sells a custom one that tucks in closer to the firewall - but it may require some thinking as far as the pushrod arrangement - ask the good Captain, he will know exactly what you need. But if you want original, a truck being parted or a WTB ad would produce results rather quickly I'd imagine.
11-09-2017, 11:06 PM | #15 |
Andy4639 , did you use any booster support braces
11-10-2017, 07:01 AM | #16 |
Old member
No what you see is all I used. The truck that I got it off of didn't have them either.
My 71 factory setup doesn't have it either. The block on the master cylinder is just a distribution block & brake light hookup and not a porportioning valve. Disc to disc and drum to drum don't need them.
12-11-2017, 01:51 PM | #17 | |
I have a basket case '71 GMC (it's a '71 cab on a '69 chassis) hence my question |
12-11-2017, 03:18 PM | #18 |
71-72 do, can’t speak for 73 and up definitively.
12-11-2017, 05:57 PM | #19 |
HEY! That looks familiar! Genuine LowLion parts on the Ramp Rat!
Matt Criswell - Lyman, SC 1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE |
03-02-2018, 10:51 AM | #20 |
a bit old but as i search this thread is most recent. I am finding that the valve in question is called a combination valve(per service manual). this seems to indicate that this is another name for proportioning valve?
Please correct any thinking here as I am trying to get my head around doing my brakes correctly and safely. It is my understanding that with front disc and rear drums the front need to be limited until the rear brake can overcome the pull back springs. my truck is missing its valve and I have purchased one online new. Problem is it has an extra port (two) for the front. Can I plug one or should I get a different combination/metering valve?
1972 GMC 157" dump |
03-02-2018, 11:24 AM | #21 | |
03-02-2018, 11:45 AM | #22 | |
I am OK running two front lines but would be happier to leave all as is, if possible, and just add a combination valve.
03-02-2018, 03:46 PM | #23 |
I don't understand why the English language is such a challenge for some on this board. Actually, not just this board, but throughout the automotive world.
com·bi·na·tion /ˌkämbəˈnāSH(ə)n/ noun: combination; plural noun: combinations 1. a joining or merging of different parts or qualities in which the component elements are individually distinct. "a combination of blackberries, raspberries, and rhubarb" An automotive COMBINATION VALVE is THREE valves COMBINED into ONE unit. It is comprised of a Metering Valve, a Pressure Differential Switch and a Proportion Valve. Each of those three items serve different functions. A Pressure Differential Switch that Andy showed you is a stand alone unit, that turns on the dash warning light and nothing else. A Pressure Differential Switch in some form, is used on dual brake systems with drum/drum and disc/drum and disc/disc. It is used with power and non-power systems. The first picture is a Combination Valve. The second picture is the exact same thing, but as three individual units. This requires a lot of plumbing.
'67 GMC 2500, 292, 4spd, AC |
03-02-2018, 06:42 PM | #24 | |
"my truck is missing its combination valve(service manuals words not mine) and I have purchased one online new. Problem is it has an extra port (two) for the front. Can I plug one or should I get a different combination/metering valve?" i will search further this evening for a better match when time is available but thought someone might have a quick answer to the outlets in question. but thanks anyways.so far they all come up with a valve that appears to separate outlets to the front brakes. but my math is simple too so i could be wrong.
03-02-2018, 07:29 PM | #25 |
The OE style combination valves have 2 front outlets that are typically plumbed directly to the left & right front calipers. But the front brake line plumbing in 71 & 72 trucks includes an inline Tee fitting so only one front outlet is needed. You can safely plug the other unused front outlet with an inverted flare plug. In fact, I believe the factory installation used a plug (rather than a special single-outlet combo valve) for the 71 & 72 trucks.
