![]() Join Date: Feb 2013
Recommend me an alternator bracket
quite a while ago I replaced the alternator in my truck and because it is a different configuration than stock it has very little throw. Roughly just enough room to get a finger between the valve cover and the alt body. It is a pain to find the right belt and squeeze it on and still have enough throw to tension it properly, especially after the belt stretches.
This summer I put a vintage air system in the truck and the compressor mounts nice a wide and is easy to get and tension a belt. This got me to thinking that there has to be a alternator bracket that will move the alternator out to a similar position as the compressor. Can anyone point me in the right direction for an alternator bracket that is not billet aluminum at will get me a little... or a lot of extra throw on a short water pump. No thread is complete without a couple pictures. |
Re: Recommend me an alternator bracket
Try Alan Grove brackets.
http://www.alangrovecomponents.com/S...Short_Pump.htm They may actually make the brackets for Vintage Air.
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
Think you can split alt and turn it 1/4 turn and put back together.Pretty easy,think that would give you bunches of adjustment then.
Keep what you got and lengthen the top bracket about 2 inches.
Easy job for a welder. |
#5 | |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
As the others guys said, re-clock the alternator.
Thanks for the help and ideas. The alt is not able to be clocked, the front half of the case with the mounting points are is one piece.
I like the welder Idea, I should have thought of that... I've got one! |
Guys clocking the alternator will not achieve anything...think about it
Stan 67 swb BLU MULE posted via flip-fone Last edited by harpo231; 11-11-2017 at 06:57 PM. |
69-82 Corvettes use the same setup and they have a longer upper bracket that should move the alternator out to the side and down a little.
should be no problem locating a belt that will fit. you wont find one by part number, if you have not already but they come in half inch increments so finding one that fits should not be a problem.
cant see what your lower braket looks like but that may also contribute to your problems. I thought re clocking the alternator front half was an excellent idea................ |
Old member
The best solution is upgrade to a 94amp 90's Buick Riviera alternator. It's got the right mount for the stock truck alternator brackets.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
