#1126 |
![]() Join Date: Jul 2009
Re: 72 K30 Build
Dang, I've really started to hate do-overs!
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ![]() 2001 GMC Sierra K2500 |
#1127 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: 72 K30 Build
Sorry to hear of the #2 bad crank seal. That is no bueno.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#1128 |
![]() Join Date: Dec 2004
Re: 72 K30 Build
Truck looks great, By any chance could you post a side profile picture?
1972 c10,2wd,long bed,250,4spd----> 1972 SWB Fleetside 4x4 12v Cummins build thread http://67-72chevytrucks.com/vboard/s...d.php?t=513791 |
#1129 | |
Re: 72 K30 Build
![]() Thanks rgreathouse, I really don’t have any dead-on profile shots yet, but this one from a couple of months ago is as close as I've got. The rear axle sets back a little like a wrecker and is perfect in relation to the goose neck bucket in the bed..
Brett ![]() 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
#1130 |
![]() Join Date: Apr 2008
Re: 72 K30 Build
Very nice project! Love all the attention to detail, this will be a solid,clean & rattle free truck for years to come! Thanks for all the pics & info
#1131 |
Re: 72 K30 Build
Thanks 72 tigger, I really appreciate your kind words. Or is it 72 t-i-double-guh-er?
![]() No truck updates yet but my part of our front room redo is all done. Mrs. 7dee2 has wanted built in shelfs on our front room fireplace wall, and of course new furniture, rug, dining room set, etc, etc, etc. I'd make some wise crack about her wood handling skills but she'd kill me, so we'll let that one go! ![]()
#1132 |
Re: 72 K30 Build
The end tables and dining room table are kind of interesting, we built all the bases and put hand hammered copper tops (fancy schmancy) from Mexico on them.
#1133 |
Re: 72 K30 Build
Damn nice work!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#1134 |
Re: 72 K30 Build
Looks very cool. missing the big screen TV though
#1135 |
Re: 72 K30 Build
Looks good- you're a man of many talents! Did you do the stone on the fireplace? Yes, my wife named my truck tigger because he's bouncy
#1136 |
Re: 72 K30 Build
Wow, you sure a handy guy! That front room looks sweet! Where did you source the hammered copper tops at? I really like the shelves and fireplace too. I think that would look cool in our dining room.
#1137 |
Re: 72 K30 Build
That's pretty funny. My mom named my Dad's 69 Longhorn Dick because every time she drove the truck it wouldn't start for her or had some issue.
#1138 | |||
Re: 72 K30 Build
Thanks Mike!
Thanks, I'm guessing we did a good job of hiding the projection system then. There's 7.1 surround mostly in the ceiling and a pull down 100"+ screen, I'm a big, big fan of big screens! ![]() Quote:
![]() https://www.ebay.com/itm/Mexican-Rou...72.m2749.l2649 Quote:
#1139 |
Re: 72 K30 Build
Very nice job on the room remodel! I like the copper table tops. I need to do something like those for my back porch.
#1140 |
![]() Join Date: Feb 2000
Re: 72 K30 Build
Outstanding build! Such quality workmanship.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#1141 | |
Re: 72 K30 Build
![]() Thank you, Yukon Jack, I really appreciate the compliments. Mentioned you and your friend’s truck in the second post of this build and hope you didn’t mind me stealing pics of your guy's kool trucks? Our K30 (El Rae or Ray, short for the Rancho El Rae motorhome cab donor) has made it back into the garage and the first order of business was to fix that crank seal. After pulling the belts and just prior to pulling off the crank pulley I noticed it hadn’t flung oil all over the right side like it had last time. It looks like something is eating the paint on the left side this time? ![]() A few seconds later the light bulb went off and I realized it’s brake fluid not oil, a little taste test next, yep, it’s brake fluid. I’d miss diagnosed earlier, in my defense, it was leaving a trail and puddling exactly as before and there is a very slight oil trail (not enough to drip) coming from that seal. Must admit the two very PO’d seconds spent diagnosing earlier might have had something to do with it? ![]() ![]() ![]() Next to verify further fired the truck with no belts and let it run until the radiator fans kicked on. Crank seal is still OK, that is the good news. Had my boy lightly push on the brake pedal without any boost and watched brake fluid run out of the 2nd new CPP PV-2 proportioning valve we’ve installed. Fluid is coming from the metering valve pretty freely, leaking from the center of the fitting around the pin. After some internet research, I’m finding a few folks have been having trouble with this particular part (chinese knock off?) from this particular vendor.
#1142 |
Re: 72 K30 Build
Well, at least it isn't the crank seal. That is a bad deal about the prop valve.
#1143 |
Re: 72 K30 Build
Not really a hard part to replace but bleeding the rear brakes again without the use of our 4-post elevator should make for a good time. Yes, I do need some cheese to go with that whine!
#1144 |
Re: 72 K30 Build
Don't feel bad, since I parked my truck to do the metal work the new passenger front caliper decided to spring a leak so once I do get the body together I'll have to replace and re bleed, it was a pita last time.
#1145 |
Re: 72 K30 Build
Yeah, they sure can be glad we figured out how to bleed the rear earlier, there's just no room between the backing plate and the spring pack without dropping the diff out…. Gotta say I do love the narrowed cab and chassis dually rears so the pain is worth it for me.
Brakes were really great before the failure but El Rae is gonna stop on a dime again! Ha, maybe as good as this kid on his skate board? ![]() Installed a 4-wheel disc, PV4 (Summit brand) combination/proportioning valve this time around and eliminating the metering valve part that failed so quickly. That particular part of the combination valve slows brake fluid to the front disc brakes for various reasons (softens nose dive, allows the rear drums to get a head start, etc.) Those who have been following a while may remember we had to enlarge the inner prop valve bore (see the 4th pic) to get the rear brakes to function correctly in the first place. The 3+3 donor had a much larger bore in the main body as well as the prop valve. It’s brake setup ran a secondary ride height prop valve in the rear that we eliminated (http://67-72chevytrucks.com/vboard/s...&postcount=395). The PV4 prop valve has a larger inner bore to start with and don’t think it’ll need to be messed with, also adding a Wilwood manually adjustable valve to the rear line this time for some control if needed.
#1146 |
Re: 72 K30 Build
Thinking it's a really good time to add a helper fuel pump and different fuel filter arrangement (pulled the old spin on deal we had been running
![]() ![]() Flatbed update; Got a phone call last week from Nova @ Semi Service the replacement CM bed is in! Somebody better get their truck back together pronto! ![]()
#1147 |
Re: 72 K30 Build
Hmm, where have I seen that helper pump recently?
#1148 |
Re: 72 K30 Build
Man, I despise those carter style lift pumps. Good luck with it. I've put a lot of those in the trash can.
![]() Very good news on the new bed though. Have a Happy Thanksgiving Brett!
#1149 | ||
Re: 72 K30 Build
![]() Downside? An additional safety feature is a pressure switch, no oil pressure no fuel pump deal (see diagram). Some folks don’t like the noise of an internal/external electric pump, these are fairly quiet as they are insulated against the mounting bracket (I do like to turn mine off if it’s not needed, hot days and cheap gas just don’t mix). They are an inexpensive pump and I wouldn’t buy the knock off’s get an actual Carter brand if you’re going down this road. Quote:
#1150 |
Re: 72 K30 Build
No, on the dodges that have those carter pumps, they are all below 10psi. All the 5.9 24v Cummins VP engines had those pumps on them as lift pumps.
Tags |
72chevy, dually, flatbed, k30, motorhome |
