Old 05-28-2002, 07:58 PM   #1
one legged lance
Junior Member
Sorry but again its asked: Spindles or Springs?
Ok I know that this has been hashed before but my wife wants me to check before the cash is spent
I am planning a complete front end rebuilt anyway so everything will come apart & I will add a frt sway bar also. I have a 72 C-10 w/ 350ci that I want to mildly lower. Only 3-4 in frt & 4-5 in rr. Ride quality is important as she would like something built for her in the future if mine turns out nice.
I have been told that since I want to run 15in truck rally's that spindles will rub or interfer.....true? Anyone done this and problems?
Rear I am thinking of a 4in coil & mabye 1in block...thoughts??
I have thought about bags all around but the cost seems high, what am I looking at? I think early classics has a spindle/spring kit for around $900 but I can do springs only for $200, how much for bags and what do they require?
Thanks for all the help even if you have given this info to 1000 b4
1 Leg Lance
one legged lance is offline   Reply With Quote
Old 05-28-2002, 08:04 PM   #2
67 C-10 LWB
67 C-10 LWB's Avatar
I'd say so go spindles w/ that much drop in front, much safer in my book, I heard throwing in that small of spring up front causes problems in front, also I've checked into bags, for all 4 corners and the pump, holding tank, valves etc is anywhere from 1500-2000 that I found, but there might be cheaper ones out there, hope this helps
Ean
1999 Silverado Ext Cab Short Box Z71
2006 Trailblazer (wifes)
2 '04 KFX400's
My Site
67 C-10 LWB is offline   Reply With Quote
Old 05-28-2002, 08:23 PM   #3
SCOTI
SCOTI's Avatar
For the best ride spend the $$ for spindles. I run 6.5" van ralleys on the front of my beater w/no probs so as long as you don't go crazy w/bspacing you won't have probs. What's best for the rear depends on your plans for the truck. Mine is very low for a daily driver & I still need to occasionally tow a car hauler so I installed a 2-wheel air ride set-up. Although initially more expensive this allows it to be low & then ready to tow @ the touch of the button, but if your not gonna put alot of stuff in the rear dropped coils w/blocks is good enough. Good luck.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-28-2002, 08:30 PM   #4
superchevy
Got big-block?
superchevy's Avatar
Got to agree, go with spindles.
I tried 3" springs on front of my truck initially, and it didn't ride right.
Went to 2" spindle and 2" spring and it now rides, sits, and handles better.
Wish I would have gone with spindles first. Would have saved a lot of time, money, and frustration.
SC
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 05-28-2002, 09:06 PM   #5
Project1970
14.1 @ 96MPH
Project1970's Avatar
Spindles all the way. I don't know who said they'd rub; I've got 15" '80s 6-lug pickup rallys and Early Classic Enterprises spindles/disc brakes up front and there's no clearance problems with the wheel itself. It could use a bit more backspacing, though.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 05-28-2002, 09:53 PM   #6
orange72
orange72's Avatar
ive got 3 inch springs on the front of mine and it rides great. eventually im gonna get 2.5 drop spindles for it to go even lower.
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4.
orange72 is offline   Reply With Quote
