Looking for THE Serpentine belt set up
Hey All,
What are some serpentine belt setups that you have used or heard of other people using on our trucks? I know I can hop on eBay and buy a kit for 1000-2500 but would really like to find something cheaper that works well. I have seen guys use stock set-ups off newer trucks..... but have no info on these. I for sure want one with an AC compressor. |
Re: Looking for THE Serpentine belt set up
I yanked mine from the yard off a 94 gmc jimmy. Bolts up perfectly. The AC compressor was for an A6 pancake style.
![]() Join Date: Dec 2015
Don't know if you're on the C10 FB page.. I'm kinda liking what this guy is doing.
https://www.facebook.com/groups/9878...essenger_share https://www.facebook.com/ron.bibb.3
'67 C10 SWB - (frame-off in progress) '78 K5 Blazer - LQ4/4L65e - 4WD |
#4 | |
![]() Join Date: Sep 2016
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
X2 - '95 burb TBI setup. (Same as 72tutone's)
Since the pics I've installed the radiator. The stock '71 upper & lower hoses fit. Also, you can pull the valve covers without removing brackets. |
Awesome feedback! thanks to everyone so far. I should have specified I am running a sbc350
Be prepared to bog your machine down bigtime if you click on that second facebook link. It's one of those never-ending web pages that just keeps on loading as you keep on scrolling. It got to nearly 1 GB of memory use and 100%CPU ( only 1 thread thankfully! ) as I got only down to September ( two months worth of posts ) before I killed it. Too much crap on there with all the video and add content that loads and runs without my consent!
Just sayin' The pulley systems are dang cool though. I'd go for the 2" belt one but I've got too little room between the BBC and the radiator! -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#9 | |
![]() Join Date: Nov 2013
there are almost always some factory serpentine set-ups on ebay........they may not look as good...but .they work as good as anything out there...
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
If going the junkyard route, don't overlook trucks with 4.3s. I got my setup from a 92 Sonoma, and it's exactly the same as B.W.'s. I think I paid $100 out the door for brackets ( with a/c delete idler ), pulleys, p/s pump, fan and hardware/braces. Bought the water pump new.
The S-10 setups for the 4.3 are almost the same as the late 89[to early 90] C truck to 95. after that is the Vortec style and it put the alt on pass side and ac on drivers, but it will work well too.v also the TBI astro vans will have the same thing too.
Make sure you use a fan and water pump off the 90-95 truck too cause they turn backwards. Now you could use a 88-89 bracket but it is steel and is not pleasing to the eye like the 90-95. The bracket will bolt right up as well as the pulley on the bottom bolting on to the balancer. Great upgrade. now if you want to use your old line just take out the pressure regulator from the back of the pump. It looks like a huge nut. Just swap it out and use your old line. It is just that simple |
#12 | |
![]() Join Date: Oct 2009
![]() Join Date: Dec 1999
Don't forget to take all the mounting hardware(bolts). Some are metric and some standard. But hard to find just the same. And you we'll need to pull the power steering pulley to get the mount off on the drivers side. Hidden bolts in that area. Ask me how I found out. Particularly the hardware. And I live in a major city. Good luck.
Smitty '71 Short Fleetside Spring Valley, Ca. |
#14 | |
Sorry, man.. I found him on the FB C-10 page.. I REALLY like his setup. I would have posted a webpage for him, had I found one.
#15 |
![]() Join Date: Jan 2003
1969 ![]() 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
#16 |
Quit if it's not FUN!!!
