Old 11-15-2017, 09:53 PM   #1
Mtblack412
Fuel gauge needle bouncing
Does anyone know what causes and how to cure a bouncing fuel gauge? It makes it a little difficult to see how much fuel is left without sitting still....lol.
Mtblack412 is offline   Reply With Quote
Old 11-16-2017, 07:09 AM   #2
Dead Parrot
Re: Fuel gauge needle bouncing
If it is a rapid bouncing, replace the gauge. I think there is a way to fix one, but for the $5 it cost for a replacement from my local pull-a-part, wasn't worth trying.
Dead Parrot is offline   Reply With Quote
Old 11-16-2017, 11:48 AM   #3
RotaryRocketeer
RotaryRocketeer's Avatar
Mine does this too. Coupled with the other odd gremlins that my cluster seems to have, I have been assuming the gauge pack just needs to be grounded better. That hasn't motivated me to fix it or anything, don't be ridiculous haha! May be worth a shot though.
RotaryRocketeer is offline   Reply With Quote
Old 11-17-2017, 05:11 PM   #4
Captain J
In old trucks, it maybe caused by bad ground at the sending unit or bad gauge, if you know basic electricity you can check, remove the the gauge and do a direct test to it, by hooking a ground & power from the battrey to the gauge and see if the needles move full deflection. If it moves and stay fully defected then gauge is ok, that tells you’ve bad ground at the sending unit, if it keep bouncing then bad gauge. I hope this help. Capt J.
Captain J is offline   Reply With Quote
Old 11-17-2017, 08:28 PM   #5
Mtblack412
Yes this helps. Thank you very much.
