Old 11-16-2017, 02:44 PM   #1
gramps77
which EFI fuel solution for dual tanks would you use?
Currently, all I have left is fuel supply with my 77 dual tank Scottsdale. My dual tanks currently work and transfer great, no issues. Adding the EFI, of course, requires higher fuel pressure and draw.
Ive read that the stock transfer valve wont hold up to fuel draw of an EFI pump, so here's my question.
I have BOTH the MSD Atomic fuel pump system I could use with the new Pollack valve (from an 87 FI dual tank system) I have to replace the stock fuel transfer pump.......OR I also have the FI Tech Fuel Command center that feeds of the stock mechanical fuel pump.
I'll be using a return system for either fuel supply so that's a non issue.
Which way would you guys go?
gramps77 is offline   Reply With Quote
Old 11-16-2017, 04:33 PM   #2
SunSoaked
SunSoaked's Avatar
Re: which EFI fuel solution for dual tanks would you use?
MSD. Then sell me your FiTech command center.
SunSoaked is offline   Reply With Quote
Old 11-17-2017, 09:24 AM   #3
sweetk30
sweetk30's Avatar
read up first on fitech fuel command centers . i have seen lots of people having problems with them .
high psi pumps for fuel always push better than suck and get cooled sitting in the fuel = why there in the tank .
i prefer the 87-91 efi tank/ sender / 96c3500 vortec 350 fuel pump thats a plug/play on a 87-91 efi sender. and you can get efi sender with out pump to save money .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 11-17-2017, 03:28 PM   #4
BamaDave
https://www.summitracing.com/parts/edl-36032
BamaDave is offline   Reply With Quote
Old 11-17-2017, 05:10 PM   #5
83GMCK2500
How many PSI are the new in-tank pumps? The Pollack valves (3-port & 6-port) are rated for 65 PSI & have 3/8" ports on the supply side.
http://products.pollakaftermarket.co...elector-valves
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 11-17-2017, 07:35 PM   #6
Tom
driving is in my blood
Tom's Avatar
So the fuel pump sucks fuel from the tanks threw the valve before pressurizing and sending it foward? That's a bit absurd and poorly designed. Pumps should push, not suck. Stock transfer valve should have fuel being forced threw it. Unless your saying the stock valve won't handle high fuel pressure?
Old 11-17-2017, 11:18 PM   #7
sweetk30
sweetk30's Avatar
stock carb style older 86-back valve wont hold is what he is trying to say .
the vortec series pump lots are using in tank are 60-65 psi rated for there specific application .
fitech and snipper use 58-59 psi .
Old 11-18-2017, 10:16 AM   #8
gramps77
Yes, he's right. Apparently the valve won't hold up to the pump draw. I already have the FCC so I guess I'll try this route. I had thought about getting rid of one tank since I should have increased fuel mileage and also have the standard MSD pump, but like the extra 20 gallons.
Old 11-28-2017, 10:21 PM   #9
SunSoaked
SunSoaked's Avatar
I'm in the process of installing the Edelbrock remote sump. I've done 3 FiTech command center installs. Regarding the "lots of people having problems", I see a common thread to the folks making this claim. It appears they don't know the difference between a return line ( related to pump bypass pressure) versus a vent line. If the pump is in the sump, why would you need a return line? On the other hand, a sump is a vessel, thus it needs to be vented, preferably back to the tank.
Old 11-29-2017, 07:02 PM   #10
Tom
Tom's Avatar
Thats where you confused me. A draw has always been a suction to me [the intake to the pump, not the pressurized output], you guys are referencing the pump output/pressure in the fuel lines. That's pushing not drawing.
Old 11-29-2017, 09:37 PM   #11
SunSoaked
SunSoaked's Avatar
This thread has become waaaaay overcomplicated.
