Old 11-17-2017, 01:01 AM   #1
Jaysonb
Jaysonb's Avatar
Door glass replacement
I'm ordering up some new door glass for the 73 I'm working on, it looks like I have to reuse the metal track on the bottom of the old glass. Anyone have any pointers? Looks like it's just wedged in there with a strip of rubber??? Thanks in advance for the help!
Jaysonb is offline   Reply With Quote
Old 11-17-2017, 10:36 AM   #2
blazer2007
Re: Door glass replacement
there is a good video on this on u tube, don,t know off hand but it pops up usually first
blazer2007 is offline   Reply With Quote
Old 11-17-2017, 11:15 AM   #3
68JOHNDEERE
Mark on the old glass the edges of the track before removing it, then measure on the new glass to center the track onto the new door glass.
To remove the metal channel off the old glass I like to use a 2 inch square piece of hard wood. Lay the glass flat on a table while someone holds the door glass, using the wood and a hammer hit the metal channel off away from the glass.
If you have a local glass shop they may have some tuff pak channel bond tape. Wrap that over the lower edge of the glass and hold it in place with strips of electrical tape. Cushion the table with a couple layers of cardboard, stand the glass on it's upper edge on top of the cardboard, then with a little glass cleaner on the tuff pak tap the metal channel onto the new glass with a rubber mallet til seated fully.
68JOHNDEERE is offline   Reply With Quote
Old 11-17-2017, 08:35 PM   #4
Jaysonb
Jaysonb's Avatar
Thanks guys!
