Old 11-22-2017, 11:30 PM   #1
tbrown5079
vacumm fitting on rear of 4.8 intake
is the vacuum fitting for the brake booster on the rear of the intake on a 4.8 removable? I'm having P0171 and P0174 issues and the brakes don't seem to be consistent. It is loose where the booster hose goes on, and turns but doesn't get any tighter or looser. What's the deal?
tbrown's 56 Cameo Build
tbrown5079 is offline   Reply With Quote
Old 11-23-2017, 07:45 AM   #2
homemade87
Re: vacumm fitting on rear of 4.8 intake
That connection is normally a loose fit . It will turn and push in and out some but will still seal . If you want to take it off push in on the fitting and then depress the red tab and then pull it off .
I would think your issues are else where .
homemade87 is offline   Reply With Quote
Old 11-23-2017, 01:42 PM   #3
tbrown5079
OK. Thanks for the response.
Old 11-25-2017, 10:13 AM   #4
truckdude239
truckdude239's Avatar
More then like the intake gaskets are leaking thats what normally causes those code come up together
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 11-27-2017, 09:04 PM   #5
tbrown5079
That' s a thought, but I just replaced them with the gaskets they recommend, so I hope that is not it. I just get the faults sporadically so I was thinking it had something to do with the check valve on the booster or something like that.
