Old 11-25-2017, 05:21 AM   #1
Timm
Converting 70 Blazer to front disc
Need 71 or 72 hub assembly. I have hubs that I was told were from a 72, so I ordered rotors and calipers. The rotors I have don't mate with the hubs, which are too big for the rotors. I'm looking for hub assembly, or a place to buy a 70 conversion kit with drilled, slotted rotors, and wilwood calipers.
Timm is offline   Reply With Quote
Old 11-27-2017, 02:56 PM   #2
harrisoncole4
harrisoncole4's Avatar
Re: Converting 70 Blazer to front disc
I've been searching for the same thing. Seems the easiest way is to just find a 71/72 k5/10 axle and swap it in.
1969 K5 Blazer - 507 Light Blue - http://67-72chevytrucks.com/vboard/s...d.php?t=802858
harrisoncole4 is offline   Reply With Quote
Old 11-27-2017, 08:04 PM   #3
1rippen6
I have some spindles and hubs from a 72 blazer I will sell.
1rippen6 is offline   Reply With Quote
Old 11-28-2017, 09:09 PM   #4
harrisoncole4
If Timm doesnt want them i would be interested.
Old 11-28-2017, 10:30 PM   #5
1rippen6
I will get some pictures Thursday and go from there.
Old 11-30-2017, 02:41 AM   #6
Timm
How much do you want?
Old 11-30-2017, 10:46 AM   #7
hemi43
hemi43's Avatar
Stock 1970 axle and hubs, with late model rotors and dual piston calipers. If you're a bit handy, it's an easy conversion and you'll have superior brakes over the early 70's style.
hemi43 is offline   Reply With Quote
Old 11-30-2017, 11:09 AM   #8
A1971Blazer
A1971Blazer's Avatar
More info please...
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 11-30-2017, 03:06 PM   #9
hemi43
hemi43's Avatar
Originally Posted by A1971Blazer View Post
More info please...
There's info on my build thread;
http://67-72chevytrucks.com/vboard/s...d.php?t=676080
Old 11-30-2017, 09:02 PM   #10
1rippen6
Here are the hubs I have, I will remove the other rotor to ship. If I remember correctly they will fit in a medium flat rate but would need to check again. 50 plus shipping a set, I have 2 sets.
Old 12-01-2017, 03:55 AM   #11
Timm
Thanks for the reply. I found a set for free today, so I won't need them any more. That is a great price.
Old 12-01-2017, 10:13 AM   #12
hemi43
hemi43's Avatar
You'll need a lot more than just the hubs !!
Good info here-----> http://77cj.littlekeylime.com/web_rs44.html
and here------------> http://www.fourwheeler.com/how-to/tr...sc-brake-swap/http://www.fourwheeler.com/how-to/tr...sc-brake-swap/
You will be further ahead buying a complete front axle and swapping parts from it.
Old 12-01-2017, 01:18 PM   #13
chadcampbell00
chadcampbell00's Avatar
I just did this conversion on my '70 Jimmy a couple of months ago and ran into all kinds of problems. In short, I ended up getting new upper and lower ball joints, inner and outer wheel bearings, seals, hubs/rotors, calipers, brake lines, outer axle shafts, inner axle shafts (because the new ones had different size u-joint holes). It seemed nothing would work together, i had a hard time getting things to work together. U-joints didn't fit both shafts, brake line fittings was different and I had a hard time getting the right adapters... I still have part numbers and websites for companies I found helpfull. If you need anything that I may could help with I'd be glad to offer and info I can
chadcampbell00 is offline   Reply With Quote
Old 12-04-2017, 03:31 PM   #14
harrisoncole4
I might have to stop by and get a closer look at how you did this when I begin my disc brake swap on my 69.
Old 12-05-2017, 12:40 AM   #15
Spf79
Spf79's Avatar
HEMI43 has an awesome fix. I would really look at his setup.
Ok, I just went through a rebuild of a dana 44, I had to replace the spindle and outer axle shaft. Looks like it was in an accident, the bottom of the rotor was ground flat. Also, lol - the PO ground off the end of the axle shaft. I think it was because they could not figure out how to get the snap ring off.
Anyways, I did some wrecking yard searching for my parts, it is my understanding that you will need everything from the knuckles out, (including knuckles)... Good news is that the knuckles and everything else is interchangeable between the Dana and 10 bolt. This gives you a fair amount of options to choose from at the wrecking yard. Here is a list I found during my adventure that laid out axle lengths. I just read on another forum that the outer axle shafts between 10 bolt and dana 44 are the same, but the inner axles are different... I am not sure about this. Might be worth your time to go to a Pick-N-Pull.
Check this link out as well.
http://77cj.littlekeylime.com/flatop_knucles.html
Again, Hemi43 has the right idea, just get another axle and swap parts. Let me know how it turns out.
Full top blazer or bust....
Spf79 is offline   Reply With Quote
