Old 11-25-2017, 11:11 AM   #1
swjtlongdrive
4" lift leaning towards drivers side
So I just installed a 4" leaf lift from rough country with new leafs and shocks in all four corners on my 1972 Jimmy. Now, my truck is leaning approx. 1" to the drivers side. Front looks to be a bit more then 1" and the rear is approx. 1". Any suggestions? I put the new steering raising arm on and everything is tightened down. I've driven it approx. 1 mile and the lift has been on for about 2 weeks sitting in the garage waiting on the final parts so it's had time to settle. Any help would be appreciated.
swjtlongdrive is offline   Reply With Quote
Old 11-25-2017, 11:36 AM   #2
72gmguy
72gmguy's Avatar
Re: 4" lift leaning towards drivers side
Did you tighten the leaf spring bolts before the truck was on the ground? That could cause the springs to bind. Try loosening all the leaf spring bolts so the truck settles before retightening.
Jeremy
1969 Blazer 4x4 original cst
1971 Blazer partial 2wd convert
1972 Blazer 4x4 original cst
1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper
1970 4x4 suburban w/ 6in lift and 35in tires
1968 Corvette convertible
1970 Malibu convertible
1959 Brookwood wagon
1972 International Scout ii
72gmguy is offline   Reply With Quote
Old 11-26-2017, 10:40 AM   #3
swjtlongdrive
Thanks 72gmguy, that's a great idea as I did tighten everything before putting it back on the ground.
