Old 11-28-2017, 04:58 AM   #26
Nut Case
Nut Case's Avatar
Re: My 57 Chevy #2 with PB Fab frame & RideTech Coilovers
-Chuck
I was looking at a post that you made in the shop area, to use a standard outlet for the ceiling fixture due to the every evolving lighting fixtures.
I'm in the final states of building my shed, I'm going to use your wisdom for my ceiling lighting.
New build looks like fun.
Keep on keepin on
NC
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 11-28-2017, 04:14 PM   #27
Russell Ashley
Russell Ashley's Avatar
Originally Posted by Nut Case View Post
-Chuck
Keep on keepin on
NC
I've never checked in to that section before I saw this post. It's like the other topics on this site, you start looking and end up spending an hour or more reading threads.
Russell Ashley is offline   Reply With Quote
Old 11-28-2017, 07:09 PM   #28
Az. Hank
Az. Hank's Avatar
Nice powder coated stuff. After I was to far along I found the PB stuff. If I do it again thats the way I'd go.
My 55 Build 55 C-4
Az. Hank is offline   Reply With Quote
Old 11-28-2017, 11:38 PM   #29
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
-Chuck
Keep on keepin on
NC
I don't remember making a post over there, but glad it helped.
ChuckDriver is offline   Reply With Quote
Old 12-05-2017, 03:47 PM   #30
RockinKees
RockinKees's Avatar
I knew you had two frames, now I see you bought an extra truck...
Surely I will follow this one too!!!
Gonna be fun!!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 12-10-2017, 12:48 AM   #31
Flames97
Flames97's Avatar
Can't wait to see more on this one!!
-Aaron
'15.5 Chevy Duramax LTZ/Z71, LML, CC/SB
'77 Chevy K10, 4" lift, 33-12.50, 350/350
'55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi (SOLD)
My 55.2 Chevy 3100 Build
Flames97 is offline   Reply With Quote
Old 03-21-2018, 09:47 PM   #32
ChuckDriver
Haven't posted in awhile, but here's an update. Picked some scrap I-beam and made a level welding table to mock up the frame. With it all squared up it will be completely welded up solid. I will probably weld up most of the bolt holes afterwards just to clean up the look a bit.
Old 03-21-2018, 11:20 PM   #33
Scottish58chev
Welding table is definitely the way to go, if i ever do another that will be the first thing to get done. looks like the start of another awesome truck.
Scottish58chev is offline   Reply With Quote
Old 03-21-2018, 11:37 PM   #34
oldman3
oldman3's Avatar
Good ideal with the welding table, going to be a super nice frame...Jim
oldman3 is offline   Reply With Quote
Old 03-22-2018, 07:31 PM   #35
Russell Ashley
Dang Chuck, you are serious about this one, LOL. SCRAP I-beams??? Who throws straight non rusted steel like that away?
Old 03-22-2018, 11:16 PM   #36
BIGglaSS
BIGglaSS's Avatar
Excellent. Definitely going to steel that idea for my next build.
BIGglaSS is offline   Reply With Quote
Old 03-23-2018, 03:07 AM   #37
Nut Case
Nut Case's Avatar
Wow that "welding table is fandamtastic!!!! Good get on the I-beams.
How many friends will it take to move it? Or are you just going to radiate yourself, turn green and do it alone?
NC
Old 03-25-2018, 02:16 PM   #38
ChuckDriver
Russell, there's a big scrap yard close by the buys/sells all types of recycled steel. They had these 2 pieces of I-beam at the perfect length!
Thanks guys!!
Old 05-21-2018, 12:41 PM   #39
ChuckDriver
Well here's an update for you guys!
I had a pro welder come to my house and weld everything up after I squared everything up and tacked it together. Decided to remove the bolts and weld up the holes to make it look a little cleaner.
This week I was finally able to put in some serious garage time and make it a roller, sort of a roller, don't have any wheels to fit the front hubs!
The RideTech coil over shocks are very nice, hope they perform half as good as they look!
Hope to keep up this pace over the summer! Next is to install a mockup motor and trans and build the exhaust and run the fuel and brake lines.
Old 05-21-2018, 12:43 PM   #40
ChuckDriver
1 more!
Old 05-21-2018, 01:05 PM   #41
Scottish58chev
That’s looking great ��
Old 05-21-2018, 07:08 PM   #42
Advanced Design
Advanced Design's Avatar
Wow, very nice!
Advanced Design is offline   Reply With Quote
Old 05-21-2018, 07:32 PM   #43
oldman3
oldman3's Avatar
Way to go JJ, very nice work...Jim
Old 06-25-2018, 09:50 PM   #44
ChuckDriver
Bolted in a mock-up motor and trans, rolled her outside to check out the stance, I like it!!
Old 06-25-2018, 11:14 PM   #45
oldman3
oldman3's Avatar
Looking good JJ...Jim
Old 06-26-2018, 12:11 AM   #46
Dan in Pasadena
Dan in Pasadena's Avatar
EVerything's looking good, JJ.
You'll probably lose 50% of the remaining space between the top of that Coke can and the underside of the frame just by putting the bodywork on.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 06-29-2018, 12:06 PM   #47
chicken835
looks good, i like it. any chance i could get a few measurements?
chicken835 is offline   Reply With Quote
Old 06-30-2018, 08:33 PM   #48
ChuckDriver
Sure, what do you need?
Old 11-21-2020, 02:20 AM   #49
G&R's57GMC
G&R's57GMC's Avatar
Last Post from JJ ChuckDriver was on 6.30.2018
Where are you JJ ?
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 11-21-2020, 09:15 PM   #50
ChuckDriver
Yes it has been a long time since I posted anything on this site. Lots of things have happened in my life that slowed any progress on my truck projects. The worst thing was the untimely passing of my wife in Feb 2019. It has been a major adjustment for me and my children, but we are doing pretty well all things considered.
At the urging of my children, I bought a new home to help with the healing process. The plus side is its a raised home with 1800 sqFt of garage space.
This summer my son and I did get to work on a few other projects. I do hope to get going again on the PB frame build.
Here's a peak at what we have been up to.
