11-29-2017, 07:29 PM | #1 |
Mercruiser 200/Crusader 185
Once upon a time, in the 1960s and then in 1969 Crusader Marine and Mercruiser used the 292 in a marine application. My boat was not originally one of those, but the previous owner was a machinist and replaced his 250 with a 292 attached to an Alpha Drive, and set it up with a closed cooling system.
Just had the engine rebuilt, and am running a quadrajet on it. Looking for tips on how to maintain it. |
11-29-2017, 07:35 PM | #2 |
Re: Mercruiser 200/Crusader 185
no different than if the engine was in a truck.....keep oil changed..tune ups are the same..plugs ,wires ,cap, rotor...
11-29-2017, 07:58 PM | #3 |
Make sure you use ALL Marine approved components. Gas fumes and sparks do not mix well in an enclosed engine compartment. Fuel pumps, Carbs, Flame arrester air filters, Distributors, Caps & Rotors, Alternators and Starters are All Marine specific.
11-29-2017, 08:51 PM | #4 |
Obviously, I'm looking more at engine cooling temperature since it's a closed loop system, could I get away with a 180 degree thermostat? Right now the engine is running under 155 degrees.
11-29-2017, 09:17 PM | #5 |
does it have a thermostat in it?..if so you can check them on the stove in a pan of water with a thermometer to make sure its working properly ....
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 11-30-2017 at 11:37 AM. |
11-30-2017, 08:50 AM | #6 |
Most all marine engines run from 155 to 165 temp . They are designed that way because of the stress a marine engine runs ( like pulling a loaded trailer up a steep hill non stop ) . 180 is to hot . Remember the coolant is not only cooling the engine but also the exhaust system . The marine electronics is designed around 160 degree temp . You start pushing into the 180,s and most likely see some detonation . I would suggest you run the highest octane gas you can fined also .
In case you are new to this there is a fresh water impeller in the lower out drive that needs to be changed( I change mine every 2 years) . It has rubber fins that will come apart( need to find all the pieces if one comes apart) and leave you stranded or a burned up motor if not caught in time . Check out utube , you will see what I am talking about . |
11-30-2017, 11:03 AM | #7 |
I've changed Alpha one impellers before. And I run 89 or 90 Octane (ethanol free if I can get it). Because it's a closed cooled system, the raw water from the heat exchanger goes to the exhaust. So I want to keep the raw water below 140. I bought Motorad High performance 160 and 180 thermostats to test. Probably go with the 160. The engine has been running rich, and the temperature has been around 150.
11-30-2017, 01:48 PM | #8 | |
