Hi. New here to this forum. Found it by trying to find answers to my problem. Any help is greatly appreciated.
I have a '69 Chevy C20 and everything was fine with my fuel Guage until I went to fill up my tank when it was empty and noticed when it was full my gauge only went to half. Now I have half a tank and it says empty. So I checked the wiring and it looks good. Did a resistance check on the sender unit. It seems to be correct with what's in the tank. So I'm guessing it's my gauge. I guess there is a resistor on the back of the gauge. Could that be the problem? If so can I purchase that only or would I have to get the whole gauge. One other thing I noticed is, when I checked the resistance at the sending unit, it only showed me a value with the key off and it was nothing when the key was on. Don't know if that's normal. Thank you for reading and I hope someone can help. |
Re: Need Help With Fuel Gauge and Sender Unit
Yes you can buy a new resistor. And you can change without pulling cluster. Let us know how it works out. That was the issue with my sons truck and it was just like you described.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
That's what I'm thinking. Now I just need to find out where to get one or make one.
#4 | ||
The Older Generation
http://www.truckandcarshop.com/trucks60_72/t60_045.html Here is a post by bigbadchev72. Quote:
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 11-29-2017 at 10:33 PM. |
![]() Join Date: Feb 2016
Welcome aboard! Here is a link with some helpful information. Good luck!
http://67-72chevytrucks.com/vboard/s...d.php?t=640615
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
The truck and car shop ones are the ticket, and don't let them fool you that they only have ones for 67-72 because these are the sames ones on 73-87.
You can also just buy resistors from an electronics store, that is how we have fixed other gauges.
Well I pulled the resistor off the gauge and checked the resistance and it was 90 Ohms. I feel like that's correct and it would mean it's not bad but maybe I'm wrong. If it is correct then I assume the gauge is bad? What do you guys think. I almost positive the sending unit is good.
Pulled the wire - gauge went past full Grounded wire - gauge went to empty Check resistance to sending unit - matches what's in the tank. Gauge resistor Ohms at 90 What else should I check? Or should I just star replacing things. Thank you again to who's helped so far and any who helps after. |
I bet your float filled up with fuel and sank to the bottom of the tank. Pretty common issue, especially if you have an aftermaket sending unit with a brass float. If you decide to get a new float make sure you get a plastic one, half of the aftermaket brass floats are garbage from the factory and you'll run into the same problem a few weeks down the road.
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296 |
Pull your sending unit out of the tank, unclip the float and give it a shake. If there's any liquid in it, throw it in the garbage and pick up a new plastic float from Summit. Here's a link...
https://www.summitracing.com/parts/o...SABEgK4TPD_BwE
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
While you have the sending unit out of the tank, connect everything up to it and ground the mounting flange to a good ground, with the key on move the float arm through it's motion and observe the gauge for the correct travel. If it follows the full travel it will prove the gauge is good or bad.
If the float is full of gas it takes more gas in the tank to raise it than the gauge is showing which is the indication you say you are getting. A bad resistor will usually only indicate 1/4 th of a tank no matter how much over that you have. I think JMD wins the prize on this one.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
