Mercruiser 200/Crusader 185
Once upon a time, in the 1960s and then in 1969 Crusader Marine and Mercruiser used the 292 in a marine application. My boat was not originally one of those, but the previous owner was a machinist and replaced his 250 with a 292 attached to an Alpha Drive, and set it up with a closed cooling system.
Just had the engine rebuilt, and am running a quadrajet on it. Looking for tips on how to maintain it. |
![]() ![]() Join Date: May 2015
Re: Mercruiser 200/Crusader 185
no different than if the engine was in a truck.....keep oil changed..tune ups are the same..plugs ,wires ,cap, rotor...
Make sure you use ALL Marine approved components. Gas fumes and sparks do not mix well in an enclosed engine compartment. Fuel pumps, Carbs, Flame arrester air filters, Distributors, Caps & Rotors, Alternators and Starters are All Marine specific.
Obviously, I'm looking more at engine cooling temperature since it's a closed loop system, could I get away with a 180 degree thermostat? Right now the engine is running under 155 degrees.
does it have a thermostat in it?..if so you can check them on the stove in a pan of water with a thermometer to make sure its working properly ....
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 11-30-2017 at 11:37 AM. |
Most all marine engines run from 155 to 165 temp . They are designed that way because of the stress a marine engine runs ( like pulling a loaded trailer up a steep hill non stop ) . 180 is to hot . Remember the coolant is not only cooling the engine but also the exhaust system . The marine electronics is designed around 160 degree temp . You start pushing into the 180,s and most likely see some detonation . I would suggest you run the highest octane gas you can fined also .
In case you are new to this there is a fresh water impeller in the lower out drive that needs to be changed( I change mine every 2 years) . It has rubber fins that will come apart( need to find all the pieces if one comes apart) and leave you stranded or a burned up motor if not caught in time . Check out utube , you will see what I am talking about . |
I've changed Alpha one impellers before. And I run 89 or 90 Octane (ethanol free if I can get it). Because it's a closed cooled system, the raw water from the heat exchanger goes to the exhaust. So I want to keep the raw water below 140. I bought Motorad High performance 160 and 180 thermostats to test. Probably go with the 160. The engine has been running rich, and the temperature has been around 150.
#8 | |
