Old 04-21-2004, 08:53 PM   #1
72c5
72c5's Avatar
Front Leaf Q
Hi suspension gang........
I just bought a 69 Blazer that is a bit too high?
Is there any easy/cheap way of lowering front ride height? I think it has front lift leafs in it...........it measures 41" from the ground to the highest part of the fender lip.......
Leafs are a 3 stack with out much arch....there is only 5" between the bump stop and the u-bolt/axle area.
The rear is a couple inches lower w/ a 2" block.......so that is pretty easy......
A few months down the road, this fall probably, I intend to put a newer 2wd front crossmember in, and dump the Dana and the leafs...
But in the interrum, I'd like to bring this beast down a little, so my wife and kids can get in, and I don't practically split my pants every time I have to hoist my ass into the truck!
Any thoughts?
I thought of flipping the leafs to reversre the arch....but then the fat leaf will be on the top.....that does not seem right.......
Then I looked at putting the leaf under the axle.......but that won't work because of the pumpkin housing on the pass side is in the way.....
The shackles do not look as if they could be any shorter either.........
Hmmm...
TIA!
72c5 is offline   Reply With Quote
Old 04-22-2004, 02:11 AM   #2
Tonyp
Tonyp's Avatar
can you get a pic of it?
guys will flip the leaf pack over or put the axle on the bottom of the leaf pack to get lift.
72 K/5
350/205
SOFT-TOP
DOUG THORLEY HEADERS
A/C
CUSTOM REAR BUMPER
http://www.socalbigdawgs.com/tr/7.18.03/DSC04290.JPG
Tonyp is offline   Reply With Quote
Old 04-22-2004, 09:12 PM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Sounds like factory springs w/ an add-a-leaf on the bottom. Take the bottom leaf out should only have 2 anyway. The block was in the rear to level it out.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
