#1476 | |
A guy with a truck
Re: How to: Ruin a perfectly good C10
I have a set of cowl-mounted Porterbuilt hinges powder coated and ready to go, but I have to install a cowl first...
So, I removed the inner cowl today to get rid of the rust problems. Seems the rubber that PO used to fill the wire run collected water underneath and rotted the firewall. Ill have a fair amount of repair to do before installing the new metal. While I had the wire wheel on the grinder cleaning rust, I decided to start removing the undercoating or bedliner or whatever it is from the firewall. I ended the day looking like a coal miner, but glad to have made some progress.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) 07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#1477 |
That is never any fun, but what a difference already. Great job.
Project Double Tap http://67-72chevytrucks.com/vboard/s...d.php?t=555901 69 Olive Verde http://67-72chevytrucks.com/vboard/s...d.php?t=734720 |
#1478 |
Wow that looks like alot of work, it will all be worth it in the end, keep up the good work.
#1479 |
A guy with a truck
Thanks for the kind words. Not fun, per se, but definitely gratifying. I am enjoying the opportunity to get in there and make it right. I was getting a little excited identifying all of the holes I want to weld up.
#1480 |
So...... more damage than expected?
#1481 | |
A guy with a truck
Meh, it’s about what I thought would be there. Lots of little holes along the wire run. I’ll have to do some interior disassembly before proceeding, to keep from starting a fire ![]()
#1482 |
A guy with a truck
Took a break from the messy cowl/firewall to deal with the messy engine. She was nice and clean on the inside, though. Cant wait to get to the no gloves required, re-assembly part...
#1483 |
A guy with a truck
Oh yeah, Im digging this:
#1484 |
#1485 |
A guy with a truck
Theyre from CFR Performance. They mount the coils under the VC, have provisions for PCV, and utilize the stock valve cover gaskets.
#1486 |
Thats gonna look good. I always toyed with the idea of making my LS look old school, Im excited to see it come together.
#1487 |
Thank you for all the detailed post. I am in the same place with that inner cowl. Looking forward to your take on it.
#1488 | ||
A guy with a truck
#1489 |
![]() Join Date: Mar 2011
So cool! Everything looks great. Digging the engine ideas.
#1490 |
Looking good!!
#1491 |
Along for the ride.
#1492 |
A guy with a truck
Thanks guys, and welcome to the circus.
After chasing the elusive 9/16 grade 8 hex and 7/16 grade 5 carriage bolts all over town because my normal bolt supplier was closed for the holiday, I managed to get the new cab mounts installed. The old rubber ones had been previously replaced with LMC units and werent that bad, actually, but the core support bushings were pretty well shot. The cab has not been square on the frame since Ive owned this truck, which caused misalignment issues with the bed, fenders, cowl, and hood. When I measured it, it was around 3/8 off side-to-side ![]()
#1493 |
A guy with a truck
The valve cover adapters are for sale here, if anyone is interested:
http://67-72chevytrucks.com/vboard/s...d.php?t=753953 They sell for $200 plus new, these were only used for mock-up. Nothing wrong with them, just decided to go a different route.
#1494 |
A guy with a truck
Worked on tearing down the interior so I can continue with the firewall and cowl repairs. Figured now was as good a time as any to get the high hump cut out...
#1495 | |
#1496 |
A guy with a truck
Yeah, if I could just make up my damned mind, this project would go a lot faster (and cheaper)...
In other news, I got the majority of the upper firewall rust taken care of and mocked-up the new inner cowl panel. It is a surprisingly good fit, but will need some massaging and smoothing (along with the firewall) before final install.
#1497 |
![]() Join Date: Sep 2015
Looking good! I like your attention to detail. Keep up the good work!
#1498 |
Nice work! Keep it up. Curious what your different route is for the valve covers. I have a set of those CFR adapters that I have plans to use in the future. Haven't brought myself to put them on yet though.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#1499 | |
![]() Join Date: Oct 2013
My first time going from low-to-high and I want to make sure I do it right the first time.
- Robbie UNITED BY TRUCKS - classic truck video content YouTube: www.youtube.com/c/unitedbytrucks Instagram: @united_by_trucks Paw Paw '68 508 Dark Blue Custom C10 Teddy '68 GMC SWB 503 Light Green LS Build Mississippi Mud '75 Skyline Blue Patina SBC Build |
#1500 | |
The stock floor basically has a formed body line in the floor that pretty much can be used as the cutting guide. You want to leave enough material past the reference holes so there's a decent flange when bolting the hump. Really was pretty straight forward for both models.
