#51 |
Re: Barger's 79 FJ40
Well it's next time
![]() Pic #1. This is the Passenger side "A" pillar that was rotted out. Pic #2. The Green/brown on the floor was the O.E. color and this was under the factory coating I removed. On the right side the A pillar was cut out. Pic #3. close up of pillar Pic #4. New piece made for repair. Pic #5. The piece being fit before welding (didnt have a shot of it finished) Till next time Mark
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
#52 |
Pic #1. Drivers side inner rocker was badly rotted so it gets cut out, the black is rust encapsulator The "A" pillar was also rotted and is fixed along with this.
Pic #2. The new piece I made to replace the bad. Pic #3. Fitting the new piece, this will end up having a large hole drilled in it for a drain plug. Pic #4. The final repair. Till next time Mark.
#53 |
UPDATE:
Sorry Guys for the Long Wait!! on the updates, I will jump around with bodywork and primer fairly quick (so not to bore) Pic 1 First rd of primer. Pic 2 After blocking,filler,primer etc Pic 3 The Green material is Fiberal A fiberglass filler I use first Pic 4 Rear floor ribs were Very time consuming!! Pic 5 Final primer. Mark
#54 |
Looks good in primer.
Now on to the painter and then to the building stage? Or am I going too fast here?
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#55 |
To be honest kees I'll let you guys vote.
The build is already complete and went home, so I have All the ammo I need to show as much as you would like to see. That being said...would you rather move forward (bypass to paint)and assembly or more primer detail? Let me know Mark
#56 |
![]() Join Date: Jul 2012
I am good with whatever you share...and paint then assembly is always exciting. Shiny new stuff!
#57 |
![]() ![]() Join Date: May 2015
Looks good...I'd also like to see it all...
#58 |
Yep I’d like to see all you do.
I’m learning..... Thanks!
#59 |
Here are some shots of the rear doors and the rot that needed my attention.
Pics 1-5 I wont go into detail (don't need to explain with these) Mark
#60 |
Nice! That edge had to have been difficult to weld. Did you back it with copper?
#61 |
No I didnt, It welded pretty good actually.
Was time consuming though.
#62 |
Pic 1 Bottom of door all metal finished.
Pic 2&3 Bottom of door sill needs repair,so I made a new piece to be welded in. Mark
#63 |
Just a few shots of some parts after bodywork and primer to move things along.
#64 |
Update:
Unfortunately while I was transferring pictures from one phone to another I lost 2000 pics! So I wont be able to show all the things I wanted. Here are the start of paint (none during)That being said I really wanted to show all the shots from under the body as I sprayed the undercoat. I call the color swamp water/baby poo brown ![]() Pic 1. Backside of front fender Pic 2. Topside just after painting. Pic 3. During wetsanding Pic 4&5 After polishing.
#65 |
i like the "swamp water do-do" brown....i bet it looks good
#66 |
Greg, It's one of those colors that grow on you!
Mark
#67 |
Awesome work again!
I like the color too, fits the car just right!
#68 |
Thank You sir!
#69 |
Update:
Pic 1. Trans cover Pic 2. Side panel Pic 3. Passenger side front & rear doors Pic 4. Rear door wetsanded Pic 5. All rubbed and polished. Mark
#70 |
Looks good Mark!
#71 |
Thanks Doug
#72 |
Nice work!
#73 |
Thanks GreenLee
#74 |
Pic 1. Here is the way I get panels prepped during wetsanding.
I use fineline tape on all the edges to protect them from burning through. Pic 2-3 after wetsanding and polish Mark
#75 |
Really nice!
Some orange pinstripes would also be nice
