Old 12-10-2017, 06:00 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Holes in fender?
When I pulled the RH inner fender some time ago, I found that someone, perhaps GM, didn't line-up the inner fender correctly. They drilled into front fender pocket and used a sheet metal screw instead of using the fixed nut as intended. It was off maybe 1/2". Someone suggested the inner fender was an after-market, but I wasn't convinced.
So today my son and I did a trial fit to determine why, and it became clear it was just laziness. The fenders line up fine, they just did it wrong. However, we noticed these holes on both fenders pictured below. They're located in approx. the same area on both fenders, only the RH fender has one more hole. I don't see a purpose for these holes, production? Have you seen this before?
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 12-10-2017, 06:36 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Holes in fender?
Looks to me like someone had a mud flap or running board flare screwed on to them.
LockDoc
Leon
Old 12-10-2017, 06:39 PM   #3
harpo231
harpo231's Avatar
Drain holes ?
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 12-10-2017, 08:14 PM   #4
71CHEVYSHORTBED402
Originally Posted by harpo231 View Post
Drain holes ?
That was my first thought, but I don't think so. SNAP!..............Doc reminded me, I think I did it when I was a kid..............I seem to recall mounting a bad idea behind each tire. They looked like a tire chock. I don't know what they're called, but wow, pretty sure that's it...........It was one of a few lame ideas I had for this truck. Just throw it on, call it cool. Yikes!
While this truck is in great shape, that makes nine additional weld spots (of many) found over the weekend. We prepped the bottom of the bed yesterday, and the painter asked about the holes in the 2nd from rear steel bed rail. We wondered if they were drain holes, but there are three near center. The two on the outside are maybe 9/16" diameter. According to my other truck there should be one in the center. Couldn't tell you why (gas tank?), it wasn't my bed to begin with.
Tony
Old 12-10-2017, 08:18 PM   #5
harpo231
harpo231's Avatar
Stan
67 swb BLU MULE
Old 12-10-2017, 08:37 PM   #6
71CHEVYSHORTBED402
...Agree. Wouldn't be my worst post. I could delete and pretend it never happened.
Tony
Old 12-10-2017, 11:58 PM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
Maybe it's a Monday truck and the installers at the assembly plant were a little hung over?
~Steven
Simi Valley, CA
Old 12-11-2017, 12:33 AM   #8
71CHEVYSHORTBED402
From what I hear they were never hungover
Tony
Old 12-11-2017, 02:01 PM   #9
Steeveedee
Who Changed This?
Steeveedee's Avatar
Fair enough. There were two bars directly across the street from the GMAD plant in Van Nuys. You'd get trampled if you didn't stay out of the way at lunch time. They served beer in pitchers instead of mugs. They'd be lined up on the bar for guys to grab and throw down.
~Steven
Simi Valley, CA
