Old 12-11-2017, 03:19 PM   #1
beaterku
beaterku's Avatar
Rear shock mount location question
Good afternoon all, I was down taking a look at the crossmember I installed this weekend and noticed something weird. The driver side shock mount holes are closer to the frame rail on the driver side than they are on the passenger side as shown below. Is this normal? I am converting from a leaf rear end so I have no prior experience with this crossmember.
Thanks!
Nick
beaterku is offline   Reply With Quote
Old 12-11-2017, 03:34 PM   #2
ChaseBBC
ChaseBBC's Avatar
Re: Rear shock mount location question
I can shoot you some pics when I get home this evening if no one replies by then. I know the pan hard bar connects in there somewhere too. maybe that's why its off. not 100% sure though without taking a look at mine.
ChaseBBC is offline   Reply With Quote
Old 12-11-2017, 03:55 PM   #3
beaterku
beaterku's Avatar
Thanks. I'm just curious which set of holes is correct if they are not supposed to be offset to one side. I've got to remove the crossmember anyway to slot some holes, so poping in a couple of holes is no biggie.
Old 12-11-2017, 07:04 PM   #4
RodnRudy
RodnRudy's Avatar
This is just an uneducated guess but maybe the factory moved the right shock over for tail pipe clearance ?
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 12-11-2017, 07:05 PM   #5
beaterku
beaterku's Avatar
You know what, you may be on to something there...
Old 12-11-2017, 07:38 PM   #6
Originalthor
Mine is 2 1/4 On the one side and the other side is at 3 1/4
Originalthor is offline   Reply With Quote
Old 12-11-2017, 08:09 PM   #7
beaterku
beaterku's Avatar
Sounds like they all might be like this. I may line them back up when I install the shocks.
Thanks!
Old 12-12-2017, 12:15 PM   #8
demian5
demian5's Avatar
For shgrins, why not email GSI or another place that produces the top shock mount bars and ask if they offset as well before blasting holes in the parts.
Sometimes things are offset for vibration, or harmonics or whatever, but the exhaust clearance makes sense. But I could swear my factory tailpipe mount (still there) is on the driver side.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 12-12-2017, 12:30 PM   #9
beaterku
beaterku's Avatar
Good idea. I emailed Travis as AZ Pro to see what he thought as well.
Old 12-12-2017, 12:48 PM   #10
Richard2112
Richard2112's Avatar
I made upper mount brackets and relocated my shocks when I built my traction link kit. All four shocks (front and rear) are now the same. I used the short front shocks.
Richard2112 is offline   Reply With Quote
Old 12-12-2017, 01:10 PM   #11
pappy 2
what I have.
pappy 2 is offline   Reply With Quote
Old 12-12-2017, 01:23 PM   #12
beaterku
beaterku's Avatar
Originally Posted by pappy 2 View Post
what I have.
Thank you for the photos. These pretty much confirm that it is offset to the driver side a bit.
