Old 12-17-2017, 08:10 PM   #1
rockyrivermark
new coil springs
1970 C10
350cu/350 auto
short bed converted
fully restored this past year and mostly stock
so my spid states that my truck has heavy duty springs. The ride is decent but I was considering changing the springs to a standard or non heavy duty if that makes sense. with 3 other trucks i used for work I have no need to load or haul with this c10.
any suggestions on whether this will make a difference?
I'm guessing heavy duty springs were and option and not standard?
any brand you could suggestion
any input appreciated.
thanks!
RRM
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 12-17-2017, 11:48 PM   #2
Pro299
Junior Member
Re: new coil springs
When I rebuilt the front end on my 72 last year I went with Moog HD. With the 1 1/4 inch sway bar I added it is pretty stiff. If I ever have to do the ball joints again I'll probably switch to standard springs. Handles the curves well, but on rough surfaces it's too harsh to be comfortable.
Pro299 is offline   Reply With Quote
Old 12-18-2017, 12:11 AM   #3
kwmech
the "heavy duty" springs on your 1/2 may be nothing more than a set for the big block or even a 3/4 ton. I would just order a set for a 1/2 ton small block
Old 12-18-2017, 12:43 AM   #4
Shinysideup
Shinysideup's Avatar
Wouldnt this be referring to the REAR springs as thats where the additional payload rides?
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 12-18-2017, 04:42 PM   #5
kwmech
Hey, keep your logic to yourself
Old 12-18-2017, 08:34 PM   #6
rockyrivermark
So checked the spid again this morning and yes it's HD rear springs. I assumed it was front and back.
Going to get standard spring and possibly 1.5" lowering blocks to level stance.
Thanks for input.
Such a great board here
RRM
My build page
