Old 12-20-2017, 01:44 PM   #1
l79m20
starter part numbers
I have a 1966 fleetside with a 250/ pg and am searching for oem part numbers that pertain to this motor/ transmissin set up. Can anyone help me out?
l79m20 is offline   Reply With Quote
Old 12-20-2017, 01:55 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: starter part numbers
Rock Auto says - ACDELCO 323364, GM Original Equipment; Remanufactured
Standard Cab Pickup; Automatic trans. W/ POWERGLIDE TRANS, DELCO SERIES 10MT Direct Drive, TYPE 101; HIGH TORQUE UNIT
Alternate/OEM Part Number(s): 10496870, 12304203, 19136156, 1988602, 323243
https://www.rockauto.com/en/catalog/...ter+motor,4152
Old 12-20-2017, 04:21 PM   #3
l79m20
Rocknod Thanks for the response! what were chevrolets part numbers? Looking to get an original rebuilder unit if I can find one!
Old 12-21-2017, 01:28 PM   #4
60-66
60-66's Avatar
Theres a couple different numbers 1107273 1107274 these are both for manual trans . 1107260 and 1107320 are the automatic numbers. These will be stamped along with the date in the starter housing. These numbers came from a 1966 Chevrolet truck parts book. Hope this helps.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
