#26 | |
Resident Curmudgeon
![]() Join Date: Dec 1999
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
#27 | |
If anyone out there has any other ideas that might work or any cars with the throttle cable to measure would be appreciated, I will also consider the shortening it as well. ![]()
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
#28 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#29 |
Stepsides Are Bedder
Done!
Ok, I ended up moving the mid-'70s pedal assembly down 2" and over 1 3/8"(measuring at the center-to-center distance between the lowermost holes of the plastic pivot plates). When I did that I now had the new pedal in exactly the same position as the stock floor mounted pedal, and the upper cable arm was aligned with the hole above the plug connector hole. The only problem with this position was that one of the pivot plate holes was over a curved area of the firewall, so I made up a 1/4" adapter plate with the 2 hole patterns in the appropriate positions and drilled and tapped it for 1/4-20 thread. I ground off the factory weld nuts and used the original bolts to bolt the plate to the firewall. I had to grind the lower bolt flush with the plate for clearance, and round the edges so the firewall insulating pad will go over it without stressing it. I filed the hole square for the cable and connected it up to check the travel...I have 2 1/2", which should be enough.
#30 |
And the finished result...
#31 |
With the stock pedal overlaid...
#32 |
I think you are going a bit nuts on this simple mod......I like the cable type pedal too......but one of the nice things about the cable is that alignment is not an issue.......just put it where it looks/works best and drill.............
this is a 5-minute mod! boom-boom be done! |
#33 | |
Resident Curmudgeon
![]() Man I missed this argument Crazyl, glad you're back! ![]()
#34 | |
What I like about doing it this way is that I don't end up with any more holes in the firewall. Also, with the pedal closer to the tranny hump, you can rest your foot against the hump on long trips...and it just plain looks right, to me, anyway, like it should be that way. But yeah, I agree with you...it doesn't have to be a long and drawn out, convoluted engineering exercise...it can be as simple (or as complex) as you want to make it. |
#35 |
I would cut the remaining crap off the pedal assemble so that it is a little cleaner. I'll post what I did on mine as well. You can see where it came out on the firewall from the previous post further up.
And to note I found a throttle cable that worked great, exact length and all, from a not sure what year S10 with a 2.0liter engine. ![]()
#36 | |
#37 |
Resident Curmudgeon
CrazyL, if I had 1/2 your talent I'd think differently too. But that "old man" reference...them's fighting words!
#38 | |
#39 |
Hey Stepsides 4 ever- You had posted some great pics on you pedal conversion, but they got lost a while back.......do you still have those pics?
#40 |
Here they are...with thanks to Orange70Chevy for the pic of the later model firewall.
These are the pix of the stock '70 setup... |
#41 |
...the first pic is a comparison between the '71-'72 cable throttle arm (on the right) and a later model arm, showing the difference in pedal offset.
The next one is a pic of the "adapter" plate that screws into the original holes (after removing the threaded nuts on the firewall) and provides a place to screw the new pedal bracket. The last two pix are of the final result, and with the original accelerator pedal overlaid on the new pedal to show how the stock position relates to the new pedal. |
#42 |
So Step- You used the later style pedal.......nice.........looks like the square hole is cut about 1" above the small round hole that is there already.......Great Pics! Thx for reposting the pics.........
#43 |
The 1 1/8" round hole is a hole for the grommet that the tail light wiring goes through.
There is a pointed rubber/plastic fastener that secures the firewall insulating pad immediately above that (where the end of the tape measure is). I popped that fastener out and filed the hole square for the throttle cable. Be aware that the later model cable requires a rectangular hole while the '71-'72 cable hole is square. |
#44 |
You guys need to check out
"Lokar" They make a cut to fit throttle cable. I got one for my 72 because I have a 8 in the 6 Cyl position and I have a T.D performance throttle/T.V cable bracket that sits a little closer to the firewall.. Works perfect. It required a stainless washer to cover the outside edges of the old square hole in the firewal lbut it still looks trick.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#45 |
oh man is this ever an old thread brought back from the dead
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
#46 |
Didnt notice it was raised from the dead. Opps
#47 |
I tryed doing the swap and ended up going back to original type rod set up till I get the bugs worked out... Good luck to you. For the square hole, I drilled a hole and then "squared " off the corners with a jig saw & metal blade & just nibbled away material till I got it right. That's the only tip I have.
I got a bench seat baby, you don't have to sit over there. |
#48 |
One of the First
![]() Join Date: Jan 2000
Re: Throttle Rod To Cable Conversion
TTT - Good info.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
#49 |
Well im glad someone already did this swap on mine, i was actually thinking it came with a cable!!
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift) 1998 S10ZR2 2005 Silverado 2500hd(tow pig) Made in the USA, just like my trucks ![]() |
