Old 12-22-2017, 12:48 PM   #1
gringoloco
A guy with a truck
gringoloco's Avatar
Captainfab D52 Rear Disc Brakes
SOLD. Complete setup includes Captainfab’s brackets (powdercoated black), Raybestos 12” rotors, rebuilt D52 calipers painted cast grey, Hawk HPS brake pads with plenty of meat, and all required hardware. Gently used as pictured
Sold plus ship. Pretty sure I can get it all in two large flat rate boxes
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-22-2017, 04:18 PM   #2
Steve Cole
Re: Captainfab D52 Rear Disc Brakes
Does this have the E brake provisions by chance?
Steve Cole is offline   Reply With Quote
Old 12-22-2017, 04:35 PM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
It is not currently setup that way, but the GM large ebrake calipers will bolt right on in place of these, if desired
-Chris
Old 12-22-2017, 05:46 PM   #4
Hidesertchevy
Pm sent
Hidesertchevy is offline   Reply With Quote
Old 12-22-2017, 06:52 PM   #5
Steve Cole
Is this a true bolt in application? Or does it need any machine work that needs done? If it's a bolt-in, and you can get it in two flat rate boxes, I will take it. Thanks
Old 12-22-2017, 07:00 PM   #6
gringoloco
A guy with a truck
gringoloco's Avatar
True bolt on, high quality parts, zero machining required. I will check if it all fits tonight
-Chris
Old 12-22-2017, 08:02 PM   #7
Steve Cole
Sounds good. Just curious, why are you selling?
Old 12-22-2017, 08:24 PM   #8
Steve Cole
Forgot to ask, it doesn't change the wheel spacing does it? Are you running the 1/2" lugs or the 7/16" lugs?
Old 12-22-2017, 10:02 PM   #9
gringoloco
A guy with a truck
gringoloco's Avatar
I’m moving to a drum in hat style parking brake setup. This is a great braking system, but I have plans to swap to a manual transmission and want the added safety of a parking brake. Now, while I have my truck in pieces seems like a good time
1/2” lugs. I went with a slightly longer stud (details in my thread), but you could get away without them or by using an extended reach lug nut. The disc hat is only minimally thicker than the drum, if at all
-Chris
Old 12-22-2017, 10:39 PM   #10
gringoloco
A guy with a truck
gringoloco's Avatar
Guys, I thought it would work, but I don’t see any way of Tetris-ing this stuff into two flat rate boxes. Let me get it packed up tomorrow and we’ll go from there.
Apologies for any inconvenience
-Chris
Old 12-22-2017, 11:21 PM   #11
crob35
In line depend on shipping to 31707 Albany,Ga. Thanks
crob35 is offline   Reply With Quote
Old 12-23-2017, 01:06 AM   #12
jessemthompson
I’ll take them if things fall through
jessemthompson is offline   Reply With Quote
Old 12-26-2017, 01:04 AM   #13
Steve Cole
Hey Gringo, hope you had a great Christmas! Just checking in to see where we are with the brakes? Thanks, Steve
Old 12-26-2017, 10:30 AM   #14
gringoloco
A guy with a truck
gringoloco's Avatar
Sold to hidesertchevy, as he was the first with an “I’ll take it”, albeit via PM
-Chris
Old 12-28-2017, 01:15 AM   #15
Steve Cole
Per the "Sellers Code of Conduct" - III. All sales must be posted in thread, a reply stating who is in line is also suggested. Accepting sales via Private Messages will result in confusion within the thread and is strictly prohibited.
I was the first one to reply "I'll take it" in the thread.
Old 12-28-2017, 11:09 AM   #16
gringoloco
A guy with a truck
gringoloco's Avatar
Based on that information, if I had it to do again, I would sell to you. Unfortunately, the item has already shipped. Thank you for the refresher and sincere apologies for any confusion this may have caused.
-Chris
