Old 12-24-2017, 10:58 AM   #1
denpw@aol.com
1972 C10 Help
I have 1972 cab. 1969 Frame (I think, it was a six cylinder, 6 lug, coil spring, long bed frame). I have all new LMC body parts to build a 1967.
I have mocked up the cab, front end, and frame. I have the 1/2 ton cab supports under the cab.
To get the fenders to line up I have 2" of clearance under the radiator core support. I don't see any radiator core support cushions that tall.
Has anyone run into this?
denpw@aol.com is offline   Reply With Quote
Old 12-24-2017, 12:53 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 1972 C10 Help
I would say you need the 3/4 ton rubber cab support cushions for your frame. The C-20 rear rubber cushions are taller than the C-10 cushions and using them would bring the core support down by about that much.... Can you post a picture of your rear cab mounts?
LockDoc
Leon
Old 12-24-2017, 01:14 PM   #3
OL SKOOL
OL SKOOL's Avatar
Re: 1972 C10 Help
I have a 70 gmc and using a 68 frame.The radiator support brackets on the frame of the 68 are different in height then the 70 I forget which way.Mine is still in pieces but i remember taking the brackets off the 70 frame cause i was going to need them.I believe thats where your trouble is.
OL SKOOL is offline   Reply With Quote
Old 12-24-2017, 06:02 PM   #4
OL SKOOL
OL SKOOL's Avatar
Re: 1972 C10 Help
See if your mount is close to the top of the frame like this one 67 gmc
Old 12-30-2017, 02:13 PM   #5
denpw@aol.com
Re: 1972 C10 Help
The cab cushions I have are about 1" tall the 3/4 tons mounts are taller so that will no help.
I've attached a picture. I have wood blocks in place of the core support mounts.
