12-30-2017, 09:38 PM | #401 |
Re: DURG's Black 65 C10
It had some cracks. I used two part epoxy.
1962 Impala SS 383 stroker Tremec TKO 600 Black 1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black 2003 100th Anniversary Road King Classic Silver Black |
12-30-2017, 09:40 PM | #402 |
They would have to face out as the air cleaner is right against the housing. I don't think that would look good. And I don't have dimple dies LOL.
12-30-2017, 09:42 PM | #403 |
I tried a little with a ball peen. I need to use it against a dolly. The snorkel metal is pretty thin but it had a flare originally, so I'm sure it can be done.
12-30-2017, 09:46 PM | #404 |
I put another hole between the writing and the snorkel today. Also installed the water outlet wand a coolant bypass hose. Started mounting a coolant overflow bottle. Measured up and ordered battery cables. Ordered 2 Auto meter pro lite 2-1/16"gauges which I am going to mount in the vertical rectangular spot on the dash.
12-31-2017, 01:22 AM | #405 |
A guy with a truck
Keep plugging away Glad to see you back on this, it was part of my inspiration to go with PB coilovers on my junk
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
12-31-2017, 09:32 AM | #406 |
Hopefully i can come see it in person this summer!!!!
05-14-2018, 09:05 PM | #407 |
Brakes done except bleeding. Added coolant. Scraping old windshield sealnt off channel. Cut holes for gages. Cut the four corner wood pieces for the bedwood.Really need to charge into replacing the entire wiring harness soon.
05-15-2018, 11:05 AM | #408 |
I'm just glad to be here!
glad to see you are still at it. seems like life can get in the way of making progress on a project...
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
05-23-2018, 05:43 PM | #409 |
Love it!
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
06-10-2018, 08:55 PM | #410 |
Couple pieces of wood fitted to the wide wheel well.
06-12-2018, 05:16 AM | #411 |
Looks great!!!
06-13-2018, 09:16 AM | #412 |
Keep at it man!
http://67-72chevytrucks.com/vboard/s...d.php?t=742865 66 SWB, C4 Dropmember timmytimm3 on IG "If you don't have time to do it right the first time, when will you?" -Dad |
06-22-2018, 03:35 PM | #413 |
Wood cut and routered. Test piece stained and varnished.
Posted via Mobile Device |
06-23-2018, 08:46 PM | #414 |
06-23-2018, 08:49 PM | #415 |
Wood stained and 2 coats of semi gloss marine varnish. Tranny cooler lines done. I think the wood will look good with the unpolished stainless strips and stainless carriage bolts.
06-25-2018, 12:36 AM | #416 |
A guy with a truck
Agreed. Gonna be a very nice, but subtle look
06-25-2018, 04:27 PM | #417 |
Rollin' Old Skool
Looking good!
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
07-07-2018, 07:28 AM | #418 |
NICE!!!! When can i test drive it??
08-13-2023, 09:53 PM | #419 |
5 year update LOL. Fired up the truck finally. 385 fast burn GM crate motor. I had been dreading installing all new wiring and finally started so I could get this thing running. Using American Autowire kit like I did on my 62 Impala.
