04-23-2004, 10:09 AM | #1 |
2A674 Tank Rat
Light socket
Does anyone know where I can get the light socket with the wire connector for my heater control face plate?
I have the non A/C style. with the lighted area to the left of the three slide arms for the defrost / air-fan / heater. I haven't seen it any where so far.
'92 GMC Sierra, Sportside, 2wd, 350, Black '92 Chevy Silverado Extended Cab 4 x 4, Blue USAFR = 2A674 = Aircraft Fuel Systems Maintenance i.e. Tank Rat |
04-23-2004, 10:13 AM | #2 |
I need these also!
T |
04-23-2004, 12:04 PM | #3 |
65 and older Chevrolets use the type of socket on the dash. If you cannot locate any in your area, let me know and I will pick one up for you. You would then wire it into the gray wire that feeds the dash lights.
Jim |
04-23-2004, 05:00 PM | #4 |
I needed one also and could not find one from all the venders I checked, so I went to the wreckers and found one there. Also another hard one to find is the side marker pig tails, later Doug
04-26-2015, 04:47 PM | #5 |
Re: Light socket
Jim. Do you happen to have 8 of the sockets with wire? I'm rebuilding my cluster. ..
04-27-2015, 02:24 AM | #6 |
Re: Light socket
I don't recall the hole size, but if it's 5/8" this may work.
http://www.repairconnector.com/produ...e-Contact.html |
04-27-2015, 02:27 AM | #7 | |
Re: Light socket
http://www.repairconnector.com/produ...Thru-1995.html |
04-27-2015, 07:01 AM | #8 |
Re: Light socket
side marker pigtails available at local autopartsd store in the help section
